Fuel Pump to Carb line for 383... #565584
12/29/09 02:02 AM
12/29/09 02:02 AM
SeventySatellite Offline OP
I'm seeing in the parts catalogs that the pump to carb line for a 1970 383 with Carter AVS is a 1 piece line and the 440 is a 2 piece line. I'm familiar with how the 2 piece allows for the vapor separator filter to be placed between the two lines. So how is the 1 piece line of the 383 setup for filter?
Re: Fuel Pump to Carb line for 383... [Re: SeventySatellite] #565585
12/29/09 02:06 AM
12/29/09 02:06 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
440 has a short J shaped line attached to the fuel pump which has an female inverted flare fitting.. 383 has a hose nipple on the fuel pump
