B-Body subframe connectors #565096
12/28/09 04:57 PM
12/28/09 04:57 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
Which ones & who from? All I see on Summit is the Competition Engineering ones. Are they good? I'll be welding these into a 67 Satellite. Thanks as always, guys.
Re: B-Body subframe connectors [Re: StealthWedge67] #565097
12/28/09 05:08 PM
12/28/09 05:08 PM
ne
broncobra Offline
broncobra  Offline
ne
I got mine from Greg, at Magnum H.P. They are the laser cut ones that fit/weld up to the contour of the floor pan.
Re: B-Body subframe connectors [Re: broncobra] #565098
12/28/09 05:10 PM
12/28/09 05:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You can also use regular square tube if you don't mind cutting into your floorboards in the area the backseat passengers feet go.
Re: B-Body subframe connectors [Re: DaytonaTurbo] #565099
12/28/09 05:43 PM
12/28/09 05:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
....best way to go about it, but I would recommend rectangular box iron (tube) widest dem, vertical, 3/16- 1/4" wall, cut thru the floor where the tube needs to be recessed, ...those floor fitting "saw tooth" u shaped subframes are a joke, some are cut down so thin, why bother
Re: B-Body subframe connectors [Re: DAYCLONA] #565100
12/28/09 06:24 PM
12/28/09 06:24 PM
Manitoba, Canada
Manitoba, Canada
Well I think a 1/4" wall is way overkill and going to add a lot of weight, quarter inch is pretty darn thick! We went with 2x3" .100 wall tube. Thicker than any of the stock framing yet reasonable on weight.
Re: B-Body subframe connectors [Re: DaytonaTurbo] #565101
12/28/09 06:27 PM
12/28/09 06:27 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I have the Comp Enginering ones on my 67 Coronet, welded in, and they work good.
Re: B-Body subframe connectors [Re: Jeff_383] #565102
12/28/09 06:43 PM
12/28/09 06:43 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
US Cartool. Best single upgrade to the Coronet ever. Drives solid, rattle free, doors shut better etc. My welder says the fit was perfect.
Re: B-Body subframe connectors [Re: DaytonaTurbo] #565103
12/28/09 07:22 PM
12/28/09 07:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I like overkill!.....plus I don't like anything under 500 HP either ..... .100 wall tube is good for exhaust pipe
Re: B-Body subframe connectors [Re: StealthWedge67] #565104
12/28/09 09:00 PM
12/28/09 09:00 PM
highland co ohio
buckeye Offline
buckeye  Offline
highland co ohio
hi just tacked mine in 2day not sure if bought from cartool or m.d.s. alittle grinding but looks good...and they are thicker than oraganal fram rail.s front or rear ..so why cut up ur floor board,s
Re: B-Body subframe connectors [Re: buckeye] #565105
12/28/09 09:10 PM
12/28/09 09:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
1/4" thick is ridiculous. Great for reinforcing a dumptruck box but has no place in this application. If you think you're making so much power that you need 1/4" wall tubing then you should be looking at more framework than just connectors! Besides, it's the tubing shape that provides most of the strength, not the thickness.
Re: B-Body subframe connectors [Re: Stanton] #565106
12/28/09 09:28 PM
12/28/09 09:28 PM
Puyallup, WA
Puyallup, WA
Fabbing from 1/4" steel box is rediculous! and I wont be cutting through the floors! The US Car Tool pieces look very nice! I'm sure they stiffen the chassis up significantly more than the C.E. ones that just weld front and rear, and are separate from the floor, between. But I'm sure you need to rip your seats and carpet out to install those. Also, my car has factory undercoating on the floors. I'd have to remove all of that..... Not that big of a deal, I know..... But I'd rather not make the job harder than it has to be. Hmmmm, What to do? In the words of George Costanza... "Why must there always be a problem!?"
Re: B-Body subframe connectors [Re: StealthWedge67] #565107
12/28/09 11:29 PM
12/28/09 11:29 PM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
We used the U S Tools ones on a 69 B Body and am pleased with the results. They were work to install as my floorpan and the parts were not an exact match so we fitted them. I hammered the floors. We also put in the spring re locating kit at the same time using info off of the A Body site. Also narrowed the rear end a few inchs. My point is it was work but it is a great upgrade and combining a couple of other steps into the project really paid off. There are other ways but this WORKS and we are very pleased with the results. Went on Power Tour last year and car was great. If you are drag racing only I would do more but this is more than enough for 440 street car.
Re: B-Body subframe connectors [Re: dragaddict] #565108
12/29/09 11:56 AM
12/29/09 11:56 AM
Minnesota
snojet Offline
snojet  Offline
Minnesota
Take a good look at what you are going to end up with. If you use the connectors that just weld to the bottom of the car you will only be connecting to a small part of the frame in back. If you cut the floor you will be able weld to the top layer of floor that transfers to the back of the car. I have done many of these and the full 2x3 tube with 1/8 is the best and longest lasting way to go.
Re: B-Body subframe connectors [Re: snojet] #565109
12/29/09 01:15 PM
12/29/09 01:15 PM
Shoreline, Washington
72roadrunnergtx Offline
Re: B-Body subframe connectors [Re: 72roadrunnergtx] #565110
12/29/09 01:32 PM
12/29/09 01:32 PM
Minnesota
snojet Offline
snojet  Offline
Minnesota
The pic's you posted are very nice and it confirms what I said. The back connection is only about 1 1/4 tall. The rest of the factory frame is above it and not connected to anything. If you are going to take the time to add the connector you mite as well go the full height and add some real support so the car won't twist. Height is strength when it come's to frame's
Re: B-Body subframe connectors [Re: snojet] #565111
12/29/09 02:30 PM
12/29/09 02:30 PM
Puyallup, WA
Puyallup, WA
Both pictures of the US Cartool connector installs are on cars being stripped and put on a rotisserie. My car is rolling, and has a very nice full original interior in place, that I don't really feel like ripping out. I'm just looking to help stiffen my car up. The Comp Eng. pieces can be installed fairly easily, and I think will offer me what I'm looking for.
Thanks fellas
Re: B-Body subframe connectors [Re: StealthWedge67] #565112
12/29/09 02:43 PM
12/29/09 02:43 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Mancini has some too, either will work fine if welded in http://chucker54.stores.yahoo.net/framconpac.html
Re: B-Body subframe connectors [Re: snojet] #565113
12/29/09 03:10 PM
12/29/09 03:10 PM
No argument here on the principles you describe, if I was building a race car, I would have no problem with cutting the floor, or anything else for that matter, to strengthen the integrity of the entire structure. My understanding of the OP's posts on this thread was the desire to stiffen his car without extensive modifications. It can be done and will result in a significant/noticeable improvement in body rigidity.
Re: B-Body subframe connectors [Re: 72roadrunnergtx] #565114
12/29/09 03:31 PM
12/29/09 03:31 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
The units that bisect the floor will provide the most strength, and if you don't want to grind all the undercoat off for contoured ones, then that pterry much leaves you with the standard tube style connectors. I think CE, Mopar, and a few others are all the same design and are desigend as a bolt in, but they can be welded on the ends. While they do not tie in the floor pan, they do offer a HUGE increase over nothing at all and will greatly reduce body deflection.
Re: B-Body subframe connectors [Re: TC@HP2] #565115
12/29/09 05:31 PM
12/29/09 05:31 PM
DennisH Offline
Vacation
DennisH  Offline
Vacation
It is worth the effort to remove the seats/carpet. The grinding off of the factory undercoating sent my welder to the emergency room with a rash. Wear protective clothing. No bolt-on will give the ridgid results that welded will.
USCartool B's fit well.
