rotor phasing? anyone see this? #565005
12/28/09 04:38 PM
12/28/09 04:38 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i cut a window in my didtributor cap on a stock mopar distributor with welded slots) to check the rotor phasing. i dont run vacuum advance.
at idle and at 300o rpm, the rotor is dead nuts with the tower contact like it should be. but when i rev it up, the phasing changes from an initial rotor to the left of the #1 tower to way right of the tower (real close to the #2 plug tower) and then it settles back to dead nuts. this only happens at the rev- a quick left then right (or maybe vice versa)
I changed to a new mopar perf distributor with the mallory advance and saw the same thing.
Both distrs had a collar on the distr drive shaft up against the oil pump gear so its not climbing up and down the slot.
I cant explain it. when the rotor is way to the right of the #1 wire's tower (Small block), the rotor looks like its just barely to the left of the #2 terminal - and that cant be possible. the spark from the rotor will jump to thew closest terminal and if it was jumping to the #2 cap terminal, my light shouldnt have fired since im on the #1 plug wire.
My only explanation is that my timing light cant keep up with the rapid change in rpm so its showing a delay during the quick rev (throttle blip).
I am using an older snap on electronic light with the rpm and digital advance function so I'd think this light would be top of the line.
Anyone else try this and see this or can explain it?
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: rotor phasing? anyone see this? [Re: aarcuda] #565006
12/28/09 04:52 PM
12/28/09 04:52 PM
Wouldn't be that. Only the vac adv range of travel will change the phasing.(is the vac adv pod still bolted on & the arm hooked into the flat plate to help anchor the plate?
Re: rotor phasing? anyone see this? [Re: aarcuda] #565007
12/28/09 04:53 PM
12/28/09 04:53 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You still have mechanical advance right? Or am I missing something here?
Re: rotor phasing? anyone see this? [Re: aarcuda] #565008
12/28/09 04:54 PM
12/28/09 04:54 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
Could your oil pump shaft be moving up and down?
Re: rotor phasing? anyone see this? [Re: buildanother] #565009
12/28/09 04:55 PM
12/28/09 04:55 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
yes. but that shouldnt do it
Re: rotor phasing? anyone see this? [Re: RapidRobert] #565010
12/28/09 04:58 PM
12/28/09 04:58 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
vac adv pod still mounted with the arm hooked up but no vacuum line. i thought maybe the vac adv plate was moving but i checked it and its pretty solid due to the spring pressure in the vac adv pod. so im pretty sure the vac adv plate isnt moving
Re: rotor phasing? anyone see this? [Re: 540DUSTER] #565011
12/28/09 04:59 PM
12/28/09 04:59 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i have a collar on the distr shaft to prevent that
Re: rotor phasing? anyone see this? [Re: aarcuda] #565012
12/28/09 05:02 PM
12/28/09 05:02 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
Has it got loose and moved?
Re: rotor phasing? anyone see this? [Re: aarcuda] #565013
12/28/09 05:04 PM
12/28/09 05:04 PM
IF your not using vacuum advance then pin the plate. only way to be sure it won't move.
Re: rotor phasing? anyone see this? [Re: aarcuda] #565014
12/28/09 05:19 PM
12/28/09 05:19 PM
That is a puzzler cause it's acting just like it has a functioning vac adv. For there to be that much of a change in the rotor arc I wonder if there IS a problem w the light. I have a pod w alot of advance (11 degrees of (dist)adv) so it can shift where the rotor is frozen by the light at up to an 11 degree arc & from your descrip if I'm reading it right you are showing alot of movement. But k.i.s.s. I'd sure be inclined to think a dist/crossfire prob as the actual culprit.
Re: rotor phasing? anyone see this? #565015
12/28/09 05:21 PM
12/28/09 05:21 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i wouldnt mind doing that. whats the best method? i tried welding it but it was a cf. the plate rides on brass pedestals as its contact points so you cant weld those. i tried welding the pin that the plate rotates on but the weld didnt hold very long.
this was on an old distributor that i experimented with
Re: rotor phasing? anyone see this? [Re: aarcuda] #565016
12/28/09 05:36 PM
12/28/09 05:36 PM
I pinned one by drilling a small hole vertical thru both plates then connected/pinned them w a small bolt/nut. Got another light you could borrow real quick?
Re: rotor phasing? anyone see this? [Re: RapidRobert] #565017
12/28/09 05:40 PM
12/28/09 05:40 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
the screw idea was the only thing i could think of too. maybe i will try it. but i am pretty sure the plate isnt moving cause it seems to be pretty taunt right now and theres really nothing that would make it move- the engine vibration is pretty good at idle and im not seeing it there. as i rev it up, it only gets smoother
i dont have another light but i'll see if i can borrow one.
i wanted to video it but i was by myself and i couldnt hold the light, the camera and blip the throttle at the same time
Re: rotor phasing? anyone see this? [Re: aarcuda] #565018
12/28/09 05:57 PM
12/28/09 05:57 PM
Clarify this: at idle & 3000 its dead centered then with a quick rev it will move slightly to the left (ccw) of #1 then it will swing cw until it is almost to #8 (you said 2 but are you meaning 8?) Correct or not correct
Re: rotor phasing? anyone see this? [Re: RapidRobert] #565019
12/28/09 06:08 PM
12/28/09 06:08 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i did this a while back so memory is kinda bad but i recall that upon reving it either moved towards #8 (cw) but still close to #1 (probably 1/8" to the left of #1- but closer to #1 than #8) and then as i let off, it moved ccw to almost at #2 (like 1/8" to 1/4" to the left of #2- but close enough that #2 should have fired since the rotor was way closer to #2 than to #1).
it was that or vice versa- reved it and it moved ccw almost on #2 and then as i let go, it moved cw towards #8 (but real close to #1- maybe a 1/8" past from #1)
at steady state either idle or at rpm, it was dead nuts on the #1 terminal
if it wasnt so cold outside right now, id start it up and verify but its too cold to start right now
Re: rotor phasing? anyone see this? [Re: aarcuda] #565020
12/28/09 06:32 PM
12/28/09 06:32 PM
Alright,thats describing about 45 degrees of phasing change!.I gotta give up (for now). You said that light had a digital advance gismo in it. I think I'd borrow someones light real quick to try & pin this down
Re: rotor phasing? anyone see this? [Re: aarcuda] #565021
12/28/09 09:03 PM
12/28/09 09:03 PM
AndyF Offline
AndyF  Offline
It doesn't surprise me at all. Whenever I look at the distributor rotor with a strobe light I always see a bunch of movement. The distributor is the end of the tail! The crank has some whip in it, the timing chain has some whip in it, the cam is winding up and releasing, the oil pump drive is adding some energy into the system, etc.
Once you start to make a bunch of power there is a real advantage to getting rid of all of that monkey motion and going with a crank trigger ignition and driving the distributor off the crankshaft. That is the way that most of the new cars do it.
Re: rotor phasing? anyone see this? [Re: AndyF] #565022
12/28/09 10:24 PM
12/28/09 10:24 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
phasing shouldn't change with timming and advance simply for one reason. Phasing just makes relation between reluctor point and rotor. So the spark is produced at rotor always at same point with reluctor because neither rotor or reluctor moves between them.
Now beginning with this statement what I thing is true ( even not an expert, just analizing ), lets start to search for the real problem.
Re: rotor phasing? anyone see this? [Re: NachoRT74] #565023
12/28/09 10:35 PM
12/28/09 10:35 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
My question is, is there even a problem present?
As mentioned, without vac advance the phasing can't change. It's not possible.
Is there a running concern, or are you just checking the phase?
I've curved distributors for several years now on an old sun machine I have. I check the phase at assembly, and that's it.
The vac pod arm should be more than adequate to hold the plate if that's what you are running. When I delete the vac advance, I use a screw to hold the plate in place, and then a special cover over the slot for the arm to hold the cap. It has a tab on it like the advance pod did, but I have used the pod not hooked up before, if that is any help to you.
Re: rotor phasing? anyone see this? [Re: dave571] #565024
12/28/09 10:47 PM
12/28/09 10:47 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Could it be that the dist turns at half speed to the crank, and that is exaggerating what you see with your timing light
