Car won't start
#563929
12/27/09 01:24 PM
12/27/09 01:24 PM
Posts: 366 San Gabriel, CA 91775
rexus31
1965 Chrysler 300. The motor (383, 4V) turns over but it won't fire. It doesn't even act like it wants to fire; it just turns over. The car is stock except for a Pertronix Flame Thrower II ignition and coil. Ballast is bypassed per Pertronix instructions. New wiring harnesses. I have not had an issue with the motor firing other than a bad coil a couple months ago. I swapped the coil this morning with one I know works and that didn't resolve the issue. I've got 12V in Run and Start. Any ideas?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Car won't start
[Re: monoptn]
#563931
12/27/09 01:31 PM
12/27/09 01:31 PM
rexus31
It ain't got no gas in it.......
It's got gas. ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: Car won't start
[Re: Sue]
#563934
12/27/09 01:54 PM
12/27/09 01:54 PM
rexus31
Re: Car won't start
[Re: Hazwoy]
#563939
12/28/09 08:04 PM
12/28/09 08:04 PM
rexus31
Here is a great link to help you-
http://www.moparaction.com/Tech/archive/roadside.html
Look at "Cranks, But Won't Start"
Thanks. I've got voltage to the coil in both the Run and Start Position but no spark from the coil. Being as I have already attempted to swap the coil with a known good one, I don't think the coil is the culprit. I think the Pertronix unit failed. I removed the Pertronix unit and sent it back to Summit for a replacement as it was still under warranty. I think I'm going back to the points and will shelf the Pertronix as a back up. The funny thing is, I've run the pertronix on my '64 GTO for 5 years with no issues. I will install the points, stock coil and ballast and report back.
Re: Car won't start
[Re: Hazwoy]
#563941
12/29/09 12:07 PM
12/29/09 12:07 PM
rexus31
The Pertronix is an awesome system. Pretty much the first mod I will do on a car. I did have a 1962 Chrysler with a 361. Had Pertronix in it and then started having running/starting problems several years later. Car had 120k miles on it , I replaced original distributor with a new Mallory distributor. It was long ago but I am pretty sure the distributor bushings were worn out on the original so no way the Pertronix could keep it firing with shaft wobble. Try another distributor maybe if your miles are up there
The distributor is new.
Re: Car won't start
[Re: Hazwoy]
#563943
12/31/09 04:49 PM
12/31/09 04:49 PM
rexus31
The Pertronix was the culprit. I put the points back in along with the stock coil and ballast and it fired right up.
Re: Car won't start
[Re: rexus31]
#563944
12/31/09 07:32 PM
12/31/09 07:32 PM
rexus31
Well I just got back from a cruise and the timing is jumping all over the place. I think I have a faulty distributor which may have shorted out the Pertronix unit. I set the timing to 10* BTDC and went for a short cruise. The car started running like it was on 4 cylinders. When I checked the timing it was 5*ATDC. I adjusted the timing to 10* BTDC and went for another ride. This time it jumped to 15* BTDC. I'll be installing a new distributor Saturday. I hope it's a bad distributor and not a bad balancer. My machinist said the balancer looked real good when the motor was rebuilt about 500 miles ago. We'll see.
Re: Car won't start
[Re: rexus31]
#563946
12/31/09 07:55 PM
12/31/09 07:55 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Aside from the distributor, you might check for timing chain slop...
Re: Car won't start
[Re: OzHemi]
#563947
12/31/09 08:23 PM
12/31/09 08:23 PM
RapidRobert
might open up the pertronix as it could be somthing simple right in front of you that you can easily deal with
Re: Car won't start
[Re: OzHemi]
#563948
12/31/09 09:53 PM
12/31/09 09:53 PM
rexus31
Timing chain is brand new, less than 500 miles on it.
