stock Indy rockers
#563562
12/26/09 10:55 PM
12/26/09 10:55 PM
Posts: 2,379 MD
Kevins493
MD
How much open pressure are they rated for? (wedge; 440-1) Thanks!
Re: stock Indy rockers
[Re: Kevins493]
#563565
12/27/09 07:52 AM
12/27/09 07:52 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
A better question will probably be: can they take 280-300 seat/800-850 open?
They won't live long with those pressures.We have used them up to 600# open and they lasted about 200/300runs,once one breaks you should change them all.We also have used them with out any problems on 650 flat soild and 680 solid roller cams with no issues for years.300/850 you better use T&D,Jesel or HS.
[Re: B G Racing]
#563567
12/27/09 03:20 PM
12/27/09 03:20 PM
Posts: 2,379 MD
Kevins493
MD
[Re: Kevins493]
#563568
12/27/09 03:26 PM
12/27/09 03:26 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I went with the Harland Sharp 1.5's on my 440-1 heads, the whole kit just bolted right on. I have a 706/661 lift roller but I don't think my pressures are as high as your asking about.
