What oil pumps are you B1 guys running? #563277
12/26/09 03:39 PM
12/26/09 03:39 PM
Anonymous OP
Anonymous OP
putting together the final pieces on my new B1 TS Motor and need suggestions on what oil pump to run?
do i go with the gerotor style like a Titan again or step up to a Johnson oil pump.
also suggestions on either dry sump or wet sump, going in a stock K frame car with center link.
I was leaning towards a Johnson wet vac pump.
pictures of oil systems with oil lines welcome.
Re: What oil pumps are you B1 guys running? #563278
12/26/09 04:57 PM
12/26/09 04:57 PM
Anonymous OP
Anonymous OP
what about the system 1 oil pump?
Re: What oil pumps are you B1 guys running? #563279
12/26/09 05:12 PM
12/26/09 05:12 PM
sweden
street_dart Offline
street_dart  Offline
sweden
Dodge Dart-67 Dodge Custom Royal Lancer-55 Dodge Dakota 4.7 -05
Re: What oil pumps are you B1 guys running? #563280
12/26/09 05:27 PM
12/26/09 05:27 PM
AndyF Online content
AndyF  Online Content
I'd run a dry sump system on a motor like that.
Re: What oil pumps are you B1 guys running? [Re: AndyF] #563281
12/26/09 05:34 PM
12/26/09 05:34 PM
Anonymous OP
Anonymous OP
AndyF i was hoping you'd chime in as i value your opinion, which pump would you use and is a dry sump going to be a PITA to run. i do alot of racing where we have to hot lap sometimes.
also need this combo to be realatively a easy turnkey operation.thanks
Re: What oil pumps are you B1 guys running? #563282
12/26/09 05:50 PM
12/26/09 05:50 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
Be careful dealing with Johnson, he thinks he walks on water. If you are going to do the dry sump route, you will not go wrong with Auto Verdi or Dailey Engineering. My PS hemi has a Dailey pump, and it makes 18" of vacuum, with no vacuum pump. Top notch stuff and it is not cheap, but, you don't want to cut corners in this department.
There are several wet sumps that are decent, but, no matter what, get a STAR vacuum pump, to go along with your wet sump system. Once again, not cheap, but, well worth it, in the long run.
Hope this helps......
www.daileyengineering.com
Re: What oil pumps are you B1 guys running? #563283
12/26/09 07:03 PM
12/26/09 07:03 PM
Going dry sump is a hassle the first time because you need to buy all the parts such as the tank, lines, filter, drive kit, etc. But once you have a dry sump setup then I doubt you would ever switch back. It is easy to pre-oil the engine, you can change the drive ratio by changing the pulleys, and the external tank provides better quality oil to the engine. If you buy the correct oil pump you won't need a vaccuum pump and you'll probably pick up some power over a wet sump setup.
If you're starting from scratch there isn't really that big of a price difference. A custom pan is going to cost the same either way. The really good wet sump oil pumps cost about the same as a dry sump pump. The cost of a vaccuum pump is roughly the same as the dry sump tank. You need a filter and hoses either way although the dry sump hoses are probably more complicated and longer.
Another nice thing about the dry sump is that you can get rid of load on the distributor gear. If you go with a belt drive distributor then you really clean up the ignition timing. For a motor on the ragged edge having the timing rock solid is worth some power and/or engine life.
Call around and chat with a few engine builders. Guys like Koffel and Best Performance seem to go dry sump on the super serious motors. My guess is that they do it for some of the reasons I listed above.
Re: What oil pumps are you B1 guys running? #563284
12/26/09 07:10 PM
12/26/09 07:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want a turn key system go with the dry sump
and a Accusump system with a solenoid. Maybe a 4
stage pump(2 in the pan and 1 in the intake valley
if you want to seal it up) that'll keep alot of oil
off the crank
Re: What oil pumps are you B1 guys running? [Re: AndyF] #563285
12/26/09 07:12 PM
12/26/09 07:12 PM
The other trick I'd do is go with an external water pump that is bolted onto the radiator. Then run dual lines on both the pressure side and the return side. That way the front of the engine is completely open for access to the pump drive and the distributor drive. You can easily change cam timing or ignition timing and you can quickly inspect everything.
With the dry sump and the Jesel distributor in place you just install a plug into the old distributor hole which then frees up space around the valve covers and intake manifold. The plug wires route better, maintenance is easier, you don't have an ignition curve to mess with, there isn't a gear driven off the camshaft (which in turn is driven off the crank), etc.
Re: What oil pumps are you B1 guys running? [Re: AndyF] #563286
12/26/09 07:16 PM
12/26/09 07:16 PM
Anonymous OP
Anonymous OP
i've been running a indy maxx reverse flow water pump system for years with great success. i know alot of guys don't like this system,something about getting air pockets deep into the head.
whats your take on a wet vac johnson oil pump?
Re: What oil pumps are you B1 guys running? [Re: MR_P_BODY] #563287
12/27/09 09:05 AM
12/27/09 09:05 AM
Anonymous OP
Anonymous OP
off the crank
mike,right now, i have 2 rear head fittings,1 front head fitting and 1 fitting below the oil pump area, trying to figure out who's pump to get?
Re: What oil pumps are you B1 guys running? #563288
12/27/09 09:06 AM
12/27/09 09:06 AM
Anonymous OP
Anonymous OP
also i forgot to mention,the oil pump hole is plugged.
Post deleted by Defbob #563289
12/27/09 11:33 AM
12/27/09 11:33 AM
Anonymous OP
Anonymous OP
Re: What oil pumps are you B1 guys running? #563290
12/27/09 01:18 PM
12/27/09 01:18 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
I agree it will be crowded with the stock K frame, may be a challenge. However, plenty of NA wedges running a dry sump system. You do not see as many true dry sump systems on blown applications(Erie Monster) because there is often positive pressure in the oil pan, same reason you do not see vac pumps with a blower. So I do not see this as as a mopar specific situation.
Advantages to the dry sump are as i understand them
1. can mount motor lower in chassis since you need very little pan depth
2. external oil reservoir for steady oil supply
3. can reduce windage hp losses
Do some motor designs benefit more from a dry sump than others (eg non skirted) sure but they all benefit from these systems.
The down sides are making them fit and the extra weight.
Just my two cents.
76 Duster work in progress
Re: What oil pumps are you B1 guys running? [Re: Edge] #563291
12/27/09 01:22 PM
12/27/09 01:22 PM
Anonymous OP
Anonymous OP
want to mention that the stock K frame has been cutout extensively and lightened, i have a jeff johnson billet fabrications low profile pan in there now with a titan oil pump but new motor i believe needs a different setup?
Re: What oil pumps are you B1 guys running? [Re: Edge] #563292
12/27/09 01:36 PM
12/27/09 01:36 PM
Anonymous OP
Anonymous OP
If you are planning on running any of the established NSS circuits NONE of them allow dry sump oil sysems. The only circuit I know of that lets you run a sheemetal intake is the NMCA and that is only for A-AAA/FX. Maximum carb size is 850. No other circuit I am aware of allows them.
Pretty sure the B1-TS heads are not allowed eighter since they said Indy Preditor heads would not pass tech. Setup would be nice for Quick-16 only problem is it would not be near quick enough in a 3000# car. Should be fun to drive though.
Post deleted by Defbob #563293
12/27/09 03:52 PM
12/27/09 03:52 PM
Anonymous OP
Anonymous OP
Re: What oil pumps are you B1 guys running? #563294
12/27/09 03:56 PM
12/27/09 03:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I just use one of those junky old KB wet sump pumps with a couple of lines to the pan..BTw for what it's worth the right oil pan on a wet sump setup is worth a good deal of power..The wrong one will cost you power.
Post deleted by Defbob [Re: Al_Alguire] #563295
12/27/09 04:01 PM
12/27/09 04:01 PM
Anonymous OP
Anonymous OP
Re: What oil pumps are you B1 guys running? #563296
12/27/09 06:14 PM
12/27/09 06:14 PM
Anonymous OP
Anonymous OP
i was leaning towards a johnson wet vac oil pump which eliminates my star vaccuum pump.
anyone ever use one before?
