firewall insulation pic, 70 ebody #563048
12/26/09 07:59 AM
12/26/09 07:59 AM
indiana
mopar mike Offline OP
indiana
i am putting the firewall insulation back into the car and i am not sure on the stick on part? got the car in a box and was not sure of the proper placement of the insulation packages? pics would be of great help. thanks moparts
Re: firewall insulation pic, 70 ebody [Re: mopar mike] #563049
12/26/09 08:15 AM
12/26/09 08:15 AM
indiana
indiana
Re: firewall insulation pic, 70 ebody [Re: mopar mike] #563050
12/26/09 11:17 AM
12/26/09 11:17 AM
indiana
indiana
no one has pic's of firewall insulation????
Re: firewall insulation pic, 70 ebody [Re: mopar mike] #563051
12/26/09 08:25 PM
12/26/09 08:25 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
i can post one tomrow
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: firewall insulation pic, 70 ebody [Re: mopar mike] #563052
12/27/09 10:22 PM
12/27/09 10:22 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a non-AC E body pic....
Re: firewall insulation pic, 70 ebody [Re: screamindriver] #563053
12/27/09 11:06 PM
12/27/09 11:06 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
My 70 hemi cuda................
Re: firewall insulation pic, 70 ebody [Re: sawdust] #563054
12/27/09 11:33 PM
12/27/09 11:33 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Along the same lines, whats the deal with the plastic pins? There are low end ones and more correct ones. Why 2 different kinds? Big price diff?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: firewall insulation pic, 70 ebody [Re: 71TA] #563055
12/28/09 08:02 AM
12/28/09 08:02 AM
indiana
indiana
thanks, big help!!!!
Re: firewall insulation pic, 70 ebody [Re: mopar mike] #563056
12/29/09 06:40 PM
12/29/09 06:40 PM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
Bump, any more pics of this? How many pins in the big piece on the right vs. the small one on left?
Thanks in advance.
EW
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
Re: firewall insulation pic, 70 ebody [Re: screamindriver] #563057
01/09/10 01:08 AM
01/09/10 01:08 AM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
How important is this insulation? There is insulation in my car now but it's kind of ratty. Would this really make a difference?
Re: firewall insulation pic, 70 ebody [Re: VITC_GTX] #563058
01/09/10 12:56 PM
01/09/10 12:56 PM
Harrisburg, Pa.
Harrisburg, Pa.
Hey guys, I just saw this thread was resurrected...There must be more than one company making those insulation nails over the years..The cheaper repops have all kinds of problems ranging from the wrong head/contour not allowing them through the firewall without a battle to being made from plastic that's too soft and not doing their job at all...I've sometimes resorted to scouring the boneyards for good originals if need be... So do your homework and ask the right questions if your buying new ones{including legnth compared to your originals}... ...Think about why it's all there...Sound deadening and heat/moisture transfer...The upper cowl insulation is glued on there so the cold/hot is'nt transfered into the seating compartment.... And back when they actually got drove in the rain it would keep the wiper transmission linkage and running water noise down....The firewall insulation{2 nails around the e-brake,7 or 8 on the big piece} did the same job but it also ended up acting as a spacer between the heaterbox and the wall itself... .. One set of insulation missing from the mix in the pic I posted is the kickpanel insulation so don't forget those pieces...They're very important in the scheme of the whole package....Usually if the cardboard backer is shot your commited to buying a new kit... I've reused some firewall/kickpanel backers and made up new yellow insulation using the fiber style home heating ductwork...It looks very close to the original yellow insulation just a touch more dense...I just peeled the aluminum facing off after using the original backer as a template...
