PT Cruiser vibration #562393
12/25/09 06:18 PM
12/25/09 06:18 PM
detroit area
moderncylinder Offline OP
detroit area
any mechanics know of issues with a slight vibration upon accleration from a stop? i havent looked at it yet but feels like bump steer you feel in the car/front end, not in the steering wheel...
Re: PT Cruiser vibration [Re: moderncylinder] #562394
12/25/09 06:20 PM
12/25/09 06:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check all your motor and trans mounts.
Re: PT Cruiser vibration [Re: stumpy] #562395
12/26/09 09:35 AM
12/26/09 09:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Look at the rear lower control arm bushings also.They tear out and might do it.When they rip all the way they clunk real good.Rocky
Chrysler Firepower
Re: PT Cruiser vibration [Re: therocks] #562396
12/26/09 11:19 AM
12/26/09 11:19 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
yep, have the front components checked out. BTW, do not raise and support any FWD car and run it to check for noises. Letting the suspension droop and running the car puts major stress on the components, since it's not designed to operate at those angles....
Re: PT Cruiser vibration [Re: moderncylinder] #562397
12/26/09 12:00 PM
12/26/09 12:00 PM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
sounds like an inner cv joint, or a mount.
Re: PT Cruiser vibration [Re: cantspel] #562398
12/27/09 01:47 PM
12/27/09 01:47 PM
Sue Offline
Sue  Offline
CV joint R&R the halfshaft
Re: PT Cruiser vibration [Re: moderncylinder] #562399
12/27/09 02:20 PM
12/27/09 02:20 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Check both torque rods on the engine. I had to change both or mind when I did my timing belt.
When the lower control arm bushing start going you'll hear squeaking and groaning from the front end a lot. The rear bushings are easy to examine by turning the wheels all the way to one side.
Re: PT Cruiser vibration [Re: NicksGarage] #562400
12/27/09 04:39 PM
12/27/09 04:39 PM
Washington Twp., Southern NJ
Fastfrankie Offline
Fastfrankie  Offline
I had an 02 PT that had the same problem as yours. Front aluminum engine mount had a hairline rip in the rubber. Its the mount below the ac compressor. Easy to fix. It tore at 58,000 miles with all easy miles - never beat on.
