Ring Gear questions - Dana 60
#560858
12/23/09 04:59 PM
12/23/09 04:59 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I just pulled the cover off my Dana and found some pitting out on the edge of the teeth. I'm thinking I was lucky as they were about to start breaking off, but thought it was interesting how they were starting to fail. Looks like there may have been too much stress put on the outside edge. Any ideas? Another question, has anyone used one of these Ultimate covers and do you have to machine the caps for the supports in the covers to work? http://www.jegs.com/i/L.P.W./619/101-60/10002/-1
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Ring Gear questions - Dana 60
[Re: WadeMetzinger]
#560860
12/23/09 06:57 PM
12/23/09 06:57 PM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
Don't have any answers, for your questions, but I found mine broken this past season, and the teeth were gone on the outside edge, just like your's is showing, never had any noise or anything out of the ordinary, only mine had taken half the tooth off,the only way I found mine, I went to change the gear oil, and teeth were falling out everywhere.
Pattern looked good, quite as a mouse, never figured out why it happened, BUT the next set I put in I took my do-more grinder, and chamfered, the outside edges of the ring, and pinion.
I thought maybe with the sharp edges of the teeth,there was cause for stress risers, with the ring gear rolling in the pinion, just my thoughts,but when I changed the gear out to go to Rockingham, it looked super good, so who knows.
P.S thanks for the mag.
[Re: 65racer]
#560861
12/23/09 07:14 PM
12/23/09 07:14 PM
from my experience , i have only seen that on regular street gears. you wont see that from a pro series gear set. i believe the pro series are a softer steel and with the more brittle regular street gears,your going to get that pitting from hard accelerating.
#560862
12/23/09 08:45 PM
12/23/09 08:45 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I was told by one of the Richmond gear reps(engineer) at the track that when you start hurting the outside edge of the teeth on the ring gear to set the pinion depth deeper(closer to the axle centerline), like .010 more than what is on the gear set for pinion depth That is suppose to help make the ring and pinion stay together better when the housing flexs at the hit of the throttle which makes the outsdie edge of the ring gear move away from the pinion which lessens the tooth contact between them BTW, it does help setting them deeper especially on 8 3/4
[Re: Cab_Burge]
#560864
12/23/09 11:23 PM
12/23/09 11:23 PM
Posts: 989 Rather be in Fallon, Nevada
RussW
super gas
super gas
A good reason to use a Moser or Strange Housing.
