gasket between trans filter and vb? #560695
12/23/09 03:47 PM
12/23/09 03:47 PM
Andrewh Offline OP
Andrewh  Offline OP
Is there supposed to be a gasket between the transmisson filter and the valvle body?
727. I saw an ad for one on ebay. The filter and a gasket.
The new one I picked up today doesn't come with one, and none of the ones listed at the parts store do either. They all come with just the pan gasket.
Re: gasket between trans filter and vb? [Re: Andrewh] #560696
12/23/09 04:02 PM
12/23/09 04:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No gasket between the filter and VB.
Re: gasket between trans filter and vb? [Re: stumpy] #560697
12/23/09 04:27 PM
12/23/09 04:27 PM
Andrewh Offline OP
Andrewh  Offline OP
Thanks. Just wanted to be sure.
Re: gasket between trans filter and vb? [Re: Andrewh] #560698
12/23/09 06:31 PM
12/23/09 06:31 PM
The listing that says "filter and gasket" would be referring to the pan gasket
Re: gasket between trans filter and vb? [Re: RapidRobert] #560699
12/23/09 11:05 PM
12/23/09 11:05 PM
Andrewh Offline OP
Andrewh  Offline OP
I thought that too, but check out this.
ebay page
Re: gasket between trans filter and vb? [Re: Andrewh] #560700
12/24/09 12:14 AM
12/24/09 12:14 AM
Thank you Andrewh, I'll remember that if I ever am selecting a filter (w gasket ) for one of the early ones.
Re: gasket between trans filter and vb? [Re: Andrewh] #560701
12/24/09 12:22 AM
12/24/09 12:22 AM
PA
U
unclemike Offline
unclemike  Offline
U
PA
ebay page
Chrysler was noted for over engineering, they probably determined the gasket wasn't needed and dropped it. Rockauto lists the early Torqueflite filter with the rear pump opening for less than $5 with a pan gasket, for those of you interested. Wix and Fram both have applications.
Re: gasket between trans filter and vb? [Re: unclemike] #560702
12/24/09 12:40 AM
12/24/09 12:40 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
FWIW If you find yourself doing a trans service on a Ford with the AOD trans there is a gasket & if you neglect to install it the trans will go into neutral everytime the driver makes a right turn... I've fixed lots of them...
Re: gasket between trans filter and vb? [Re: 1_WILD_RT] #560703
12/24/09 01:02 AM
12/24/09 01:02 AM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
I've never rebuilt a mopar trans older than 1968,but there was never a gasket.I've also dealt with pat blais before on older trans parts and he is the best.
Re: gasket between trans filter and vb? [Re: 1_WILD_RT] #560704
12/24/09 01:02 AM
12/24/09 01:02 AM
PA
U
unclemike Offline
unclemike  Offline
U
PA
Reminds me of the time I did the filter on the missus' Mustang Cobra. I didn't know the filter held a check ball in place. Lucky it landed in the shop rag.
Re: gasket between trans filter and vb? [Re: unclemike] #560705
12/24/09 01:45 AM
12/24/09 01:45 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'm not aware of a check ball, was it round or did it have a mushroom shape?
Re: gasket between trans filter and vb? [Re: 1_WILD_RT] #560706
12/24/09 01:54 AM
12/24/09 01:54 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Sort of like one of those mystery-assembly-piece-that-isn't-needed-but-freaks-out-the-tech-that-does-the-first-service plastic thingies?
Down to just a blue car now.
Re: gasket between trans filter and vb? [Re: Andrewh] #560707
12/24/09 02:02 AM
12/24/09 02:02 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
ebay page
GOOD flowing filter ... probably the best HP filter out there. The gasket is needed to seal the metal-to-metal contact ... but is not required on the stock-type dacron. And it WILL fit the later model trans ... but for almost 35 beans ? ..
A tad on the pricey side !
Re: gasket between trans filter and vb? [Re: 68HemiB] #560708
12/24/09 02:21 AM
12/24/09 02:21 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah sorta like that.. It's a seal plug to keep dirt out of the dipstick hole of the trans between the tranny being built & installed.. They had a typical cap-plug that had to be removed but found that it was quicker to have a plug that could be pushed itno the tranny while installing the dipstick...
Re: gasket between trans filter and vb? [Re: 1_WILD_RT] #560709
12/24/09 02:49 AM
12/24/09 02:49 AM
PA
U
unclemike Offline
unclemike  Offline
U
PA
It's been ages since either a ball or a small rod or pin with a spring. I think I realized what I did when I was looking up the pan bolt torque or band adjustment value before I put the pan on. One of those deals where I didn't read the FSM before I started because who would use the filter body to retain vital parts?
