Re: gasket between trans filter and vb?
[Re: Andrewh]
#560698
12/23/09 06:31 PM
12/23/09 06:31 PM
RapidRobert
The listing that says "filter and gasket" would be referring to the pan gasket
[Re: Andrewh]
#560700
12/24/09 12:14 AM
12/24/09 12:14 AM
RapidRobert
Thank you Andrewh, I'll remember that if I ever am selecting a filter (w gasket ) for one of the early ones.
[Re: Andrewh]
#560701
12/24/09 12:22 AM
12/24/09 12:22 AM
Posts: 106 PA
unclemike
PA
I thought that too, but check out this.
ebay page
Chrysler was noted for over engineering, they probably determined the gasket wasn't needed and dropped it. Rockauto lists the early Torqueflite filter with the rear pump opening for less than $5 with a pan gasket, for those of you interested. Wix and Fram both have applications.
[Re: unclemike]
#560705
12/24/09 01:45 AM
12/24/09 01:45 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Reminds me of the time I did the filter on the missus' Mustang Cobra. I didn't know the filter held a check ball in place. Lucky it landed in the shop rag.
I'm not aware of a check ball, was it round or did it have a mushroom shape?
[Re: Andrewh]
#560707
12/24/09 02:02 AM
12/24/09 02:02 AM
Posts: 30,470 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
ebay page
GOOD flowing filter ... probably the best HP filter out there. The gasket is needed to seal the metal-to-metal contact ... but is not required on the stock-type dacron. And it WILL fit the later model trans ... but for almost 35 beans ? ..
A tad on the pricey side !
[Re: 68HemiB]
#560708
12/24/09 02:21 AM
12/24/09 02:21 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Sort of like one of those mystery-assembly-piece-that-isn't-needed-but-freaks-out-the-tech-that-does-the-first-service plastic thingies?
Yeah sorta like that.. It's a seal plug to keep dirt out of the dipstick hole of the trans between the tranny being built & installed.. They had a typical cap-plug that had to be removed but found that it was quicker to have a plug that could be pushed itno the tranny while installing the dipstick...
[Re: 1_WILD_RT]
#560709
12/24/09 02:49 AM
12/24/09 02:49 AM
Posts: 106 PA
unclemike
PA
It's been ages since either a ball or a small rod or pin with a spring. I think I realized what I did when I was looking up the pan bolt torque or band adjustment value before I put the pan on. One of those deals where I didn't read the FSM before I started because who would use the filter body to retain vital parts?
