Page 2 of 4 1 2 3 4
Re: 11.75" rotors which cars ? [Re: RTshaker] #560507
12/23/09 11:07 PM
12/23/09 11:07 PM
PA
U
unclemike Offline
unclemike  Offline
U
PA
If you want to go new Jegs sells the kit with the 10.85 rotors for less than $500 new that includes the proper spindle. The ultimate good fit cheap way is the spindles and caliper adapters off a later 1973 Duster or Dart then buy the rotors, bearings and calipers new. The second best cheap way is any Aspen, Volare', Diplomat Grand Fury Spindles and adapters.
Note that the later spindle for the iso mount K-member used on Diplomat, Aspen, Volare', Grand Fury, Caravelle, St Regis, B-body Cordoba, Sebring, and Dodge is slightly taller.
As has been noted the spindles and the adapters can be mounted on either side depending on how you want the calipers, leading or trailing.
The FJM-body Diplomat, Grand Fury and the later Cordoba never came with the bigger rotors. The heavy duty cop and taxi brake option for those cars was an 11 inch rear drum.
Something to consider how the car will be driven and what kind of tire you can fit under it.
For my Diplomat I made the swap to the bigger rotors because I beat the crap out of it (drove it like a rental car) and had the optional 225/70 15" tires on it. If you are doing a resto-mod the 10.85 rotors will give you decent braking and good service.
Once you get the 10.85 set up all you will need is the adapters and rotors to upgrade to the bigger set up.
Re: 11.75" rotors which cars ? [Re: Stanton] #560508
12/23/09 11:10 PM
12/23/09 11:10 PM
PA
U
unclemike Offline
unclemike  Offline
U
PA
It seems the pin type are preferred but you can't buy "new" pins so you're dinked if the pins are rotten or worn.
http://www.rockauto.com/catalog/moreinfo.php?pk=904748
You mean these pins?
Don't believe everything that magazine writer that sells parts on Fleabay tells you.
Re: 11.75" rotors which cars ? [Re: unclemike] #560509
12/23/09 11:20 PM
12/23/09 11:20 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Rebuilt calipers also come with new pins.
Re: 11.75" rotors which cars ? [Re: DoctorDiff] #560510
12/23/09 11:28 PM
12/23/09 11:28 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
bought new pins at "then and now auto" in stock
Re: 11.75" rotors which cars ? [Re: RTshaker] #560511
12/23/09 11:54 PM
12/23/09 11:54 PM
Smyrna,TN.
cudagregs Offline
cudagregs  Offline
Smyrna,TN.
I just picked my calipers up from Autozone today for my 70 cuda 11.75 caliper swap. I bought fatman fabrications 2" drop spindles. I found my set of pin style calipers at pull a part from a 77 Fury. You have to know the measurements on the pin hole distances because the 10.75 rotors look the same but are different. I would send you a link on the swap but i'm out of town now and it's on my home computer. Do a google search on cuda 11.75 cordoba brake swap. You should find the link i used for parts and directions on how to do it. I test fitted my parts today and everything looks great. Good luck and Merry Christmas!
Re: 11.75" rotors which cars ? [Re: DoctorDiff] #560512
12/23/09 11:55 PM
12/23/09 11:55 PM
PA
U
unclemike Offline
unclemike  Offline
U
PA
I buy Cardone rebuilt calipers exclusively from Rockauto, they come complete with all the slider hardware. The only problem I ever had was once the box had the wrong side caliper, they sent me the proper caliper on their dime, no questions asked.
If I'm not going with factory part I but Cardone remanned or Cardone Select new stuff.
Re: 11.75" rotors which cars ? [Re: cudagregs] #560513
12/23/09 11:58 PM
12/23/09 11:58 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
http://www.moparaction.com/Tech/archive/disc-main.html
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 11.75" rotors which cars ? [Re: RTshaker] #560514
12/23/09 11:59 PM
12/23/09 11:59 PM
Smyrna,TN.
cudagregs Offline
cudagregs  Offline
Smyrna,TN.
http://www.moparaction.com/tech/archive/disc-main.html
This is the link i was talking about. Click on the parts list and scroll down. It will list all the individual parts.
Re: 11.75" rotors which cars ? [Re: cudagregs] #560515
12/24/09 12:00 AM
12/24/09 12:00 AM
PA
U
unclemike Offline
unclemike  Offline
U
PA
What is the quality and country of manufacture of the Fatman spindles? Also how $$$.
Re: 11.75" rotors which cars ? [Re: unclemike] #560516
12/24/09 12:28 AM
12/24/09 12:28 AM
Smyrna,TN.
cudagregs Offline
cudagregs  Offline
Smyrna,TN.
The Fatman spindles are made in the USA and the quality and fitment are great. They are pricey i paid 550 for mine. I already have mine installed. I had to use the cordoba calipers because the brake hose will not clear the other type of calipers that the link posted here said to use. The caliper on the Fatmans mounts at the 9 o'clock position instead of the 10 o'clock on mopar spindles....
Re: 11.75" rotors which cars ? [Re: unclemike] #560517
12/24/09 12:46 AM
12/24/09 12:46 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If the price is close the forged Magnum Force spindles are a much more stouter well built piece.
That said, I have never here of someone bending or breaking a Fatman. I do know of someone with an aftermarket custom brake setup that would rub the fatman but not a stock spindle.
Re: 11.75" rotors which cars ? [Re: cudagregs] #560518
12/24/09 12:48 AM
12/24/09 12:48 AM
Florence, Alabama
72440dart Offline
72440dart  Offline
Florence, Alabama
I got two sets of pin type, one set on my dart and a spare set. I bought new pins when i did my dart. I think they were wagner.
Re: 11.75" rotors which cars ? [Re: 72440dart] #560519
12/24/09 01:05 AM
12/24/09 01:05 AM
PA
U
unclemike Offline
unclemike  Offline
U
PA
I'm partial to the slider set up because that's what I found first.
Re: 11.75" rotors which cars ? [Re: unclemike] #560520
12/24/09 07:05 AM
12/24/09 07:05 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I found the pin type adapters on a 77 Grand Fury. Big 11.75 cop car discs on a 318 car...
Think I paid all of $14 for the pair at the local Pull & Save.
Man! I love junk yards!!!
BTW, You can apparently get trick cross drilled and slotted rotors for any of the older Mopar application at Brake Performance.com - link
That would certainly put a cool new spin on the old FMJ disc swap.
Re: 11.75" rotors which cars ? [Re: RTshaker] #560521
12/24/09 07:02 PM
12/24/09 07:02 PM
Vitoria, Spain
Coke Offline
Coke  Offline
Vitoria, Spain
I have 11.75 Cordoba discs with 90īs Dodge Viper Calipers on my 69īCharger .
The spindles are from a 73 a-body with drum brakes.
Re: 11.75" rotors which cars ? [Re: Coke] #560522
12/24/09 07:12 PM
12/24/09 07:12 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Are you happy with that setup? I'm gathering parts for the swap. I have the spindles and finally tracked down a good set of Viper calipers today at a reasonable price. What size wheels are you running? I'm hoping and praying it will fit inside my 15" Halibrand 5-spokes.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: 11.75" rotors which cars ? [Re: CompSyn] #560523
12/25/09 12:21 AM
12/25/09 12:21 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Isn't the 77 Gran Fury a C-body?
Re: 11.75" rotors which cars ? [Re: Stanton] #560524
12/25/09 11:11 AM
12/25/09 11:11 AM
E Central IN
N
nd65 Offline
nd65  Offline
N
E Central IN
My pin calipers came with new pins. I think I ordered them for a 73 Challenger.
Re: 11.75" rotors which cars ? [Re: AndyF] #560525
12/25/09 02:36 PM
12/25/09 02:36 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
I used to find R body cars in the wrecking yard on a fairly regular basis but not anymore. At one point I had a very large box full of those 11.75 adapters but now they are all gone. I wish someone would reproduce them. Seems like a sure money maker. For some reason the aftermarket only reproduces the weeny adapter and not the big one.
would people want the sliders or the pin type? I've got a set of sliders currently holding a box down from floating, I can do some measurements and some CAD work. I'd have to find a set of pin type...
1971 Challenger
Re: 11.75" rotors which cars ? [Re: @#$%&*!] #560526
12/25/09 03:11 PM
12/25/09 03:11 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
fury was the B, gran fury the C for '77 IIRC. he probably got them from a fury. IIRC C body rotors are the same as 1/2 ton trucks, and are 1.25" thick
2017 Grand Cherokee Overland
Page 2 of 4 1 2 3 4
