Source for stock 727 tranny pan #560203
12/22/09 07:29 PM
12/22/09 07:29 PM
Anonymous OP
Anonymous OP
Can anyone suggest a source for a stock, stamped steel, 727 transmission pan for my 67 GTX? I give up trying to straighten the old one out so it doesn't leak and I don't want a custom pan on it.
Re: Source for stock 727 tranny pan #560204
12/22/09 07:34 PM
12/22/09 07:34 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Do you have a local pick a part yard?
That would be the cheapset easiest place to find one I suspect.
Re: Source for stock 727 tranny pan #560205
12/22/09 08:04 PM
12/22/09 08:04 PM
Andrewh Offline
Andrewh  Offline
There are a few on ebay. Stock depth but chrome with a drain plug put in. Some deeper ones as well.
all of them were around 30 with shipping.
Re: Source for stock 727 tranny pan [Re: WILD BILL] #560206
12/22/09 08:13 PM
12/22/09 08:13 PM
Anonymous OP
Anonymous OP
Sorry but my current pan probably falls in that category now and I can't get one corner of it straightened up enough to stop if from leaking. Getting tired of buying large amounts of trans fluid and want to start with a new, straight pan.
Re: Source for stock 727 tranny pan #560207
12/22/09 08:16 PM
12/22/09 08:16 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
It's ever so slightly different for the originals , but you can still buy a stock depth pan from any Mopar dealer
Re: Source for stock 727 tranny pan [Re: gtx6970] #560208
12/22/09 08:18 PM
12/22/09 08:18 PM
Andrewh Offline
Andrewh  Offline
the other thing is, are you sure it is the pan?
I have spent alot of time resealing a pan only to find it was the shifter seal or the dipstick.
REally looked like the pan every time.
Re: Source for stock 727 tranny pan [Re: Andrewh] #560209
12/22/09 08:20 PM
12/22/09 08:20 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Or the Oring that seals the rear band pivot pin.
" The last official act of any goverment, is to loot the treasury" George Washington
Re: Source for stock 727 tranny pan [Re: zzyzxpat] #560210
12/22/09 08:27 PM
12/22/09 08:27 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Clean throughly and let dry. Brake clean would be good. Dust W/ baby powder and you will see where it is leaking from.
Re: Source for stock 727 tranny pan [Re: WILD BILL] #560211
12/22/09 08:52 PM
12/22/09 08:52 PM
Seattle Wa
PowerWagonDude Offline
Seattle Wa
I get all my transmission work done by "Pat Blais Transmissions" 206-365-1966 He is the trans. guru. I have been dealing with him for about 30 years and he is the best. He has new and originall parts. Check out his Ebay store
http://stores.ebay.com/TFlite-Pattys-Shop-Mart
Re: Source for stock 727 tranny pan [Re: PowerWagonDude] #560212
12/23/09 08:33 PM
12/23/09 08:33 PM
Anonymous OP
Anonymous OP
No, it's the pan. It started when I pulled it to fix the kickdown linkage inside that was not tightened down and came disengaged. I've tried to straighten the flange out twice now and it still leaks in the one corner that the bolts don't clamp well. Our local Chrysler dealer won't even talk to me about any thing thats more than 10 to 15 years old. They just tell me to go away. I'll check out the Ebay site and see if I can locate one there.
Dan
Re: Source for stock 727 tranny pan #560213
12/23/09 09:07 PM
12/23/09 09:07 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Dan I sent you a pm I have a good straight one from my 71 cuda if you need one.
Re: Source for stock 727 tranny pan [Re: ireland383] #560214
12/23/09 10:12 PM
12/23/09 10:12 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
An A518 pan will work
Re: Source for stock 727 tranny pan #560215
12/24/09 01:19 AM
12/24/09 01:19 AM
PA
U
unclemike Offline
unclemike  Offline
U
PA
Re: Source for stock 727 tranny pan [Re: unclemike] #560216
12/24/09 01:31 PM
12/24/09 01:31 PM
md
mopars4ever Offline
mopars4ever  Offline
md
get a deep mopar plain steel pan p3690730, you won`t even notice it`s not oem, has a drain plug too!
