Re: How much tire pressure?2500 ram truck
[Re: WILD BILL]
#559995
12/22/09 05:48 PM
12/22/09 05:48 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
I have been in the tire business for 15 years. Go by what the sticker says. I always go by the vehicle manufacturer specifications
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 68Cbarge]
#559998
12/22/09 10:41 PM
12/22/09 10:41 PM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
wouldn't it be better to go by what it says on the TIRE?? the sticker was for the factory installed tires...who can say what's on it now.
[Re: Crabra]
#560002
12/23/09 07:55 AM
12/23/09 07:55 AM
Posts: 5,964 Greenville, PA
redraptor
Greenville, PA
Hi all I have a 98 dodge ram 2500 4x4.I have Lt265/75r16 tires on it.What tire pressure are you all running.Gas engine not diesel.Thanks.
He has the right tires LT not P-metric. Check the door placard to see if you have the recommended tire then inflate to the recommended psi.
[Re: 69MOPE]
#560005
12/23/09 04:07 PM
12/23/09 04:07 PM
Posts: 1,249 Las Vegas
JeffC
Las Vegas
Be careful, if the sticker calls for high pressures for load range E tires and someone put on load range D or LT tires that have a max pressure of 35 or 44, and you inflate to door sticker specs (60 to 80) you will be creating an unsafe condition.
You would already have an unsafe condition if your using tires that don't meet the load range for the vehicle.
[Re: Paul_Fancsali]
#560007
12/23/09 08:26 PM
12/23/09 08:26 PM
Posts: 1,030 ohio
67mprfan
ohio
I have a 96 ram 2500 when the 1st time i inflated to 80psi the truck rolled as smooth as a car just my 2cts
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
