How much tire pressure?2500 ram truck #559991
12/22/09 02:18 PM
12/22/09 02:18 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Hi all I have a 98 dodge ram 2500 4x4.I have Lt265/75r16 tires on it.What tire pressure are you all running.Gas engine not diesel.Thanks.
Re: How much tire pressure?2500 ram truck [Re: Crabra] #559992
12/22/09 02:33 PM
12/22/09 02:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What does the sticker on the door say?
Re: How much tire pressure?2500 ram truck [Re: stumpy] #559993
12/22/09 04:00 PM
12/22/09 04:00 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Go by what the tire recommends not the door. Somebody may have put a ten ply tire on that requires 60+ psi tire pressure. I run 65# in my load range E cooper discoverer tires. The door sticker says only 50# I believe.
Re: How much tire pressure?2500 ram truck [Re: Posest] #559994
12/22/09 04:49 PM
12/22/09 04:49 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
The rating on the side wall of the tire is for max load.
Use the rating on the door sticker.
Re: How much tire pressure?2500 ram truck [Re: WILD BILL] #559995
12/22/09 05:48 PM
12/22/09 05:48 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
I have been in the tire business for 15 years.
Go by what the sticker says.
I always go by the vehicle manufacturer specifications
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: How much tire pressure?2500 ram truck [Re: 68Cbarge] #559996
12/22/09 06:22 PM
12/22/09 06:22 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Can't go wrong with manufacturer specs.. Every vehicle has that sticker in the door.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: How much tire pressure?2500 ram truck [Re: DemonDust] #559997
12/22/09 10:02 PM
12/22/09 10:02 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
X2
Re: How much tire pressure?2500 ram truck [Re: 68Cbarge] #559998
12/22/09 10:41 PM
12/22/09 10:41 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
wouldn't it be better to go by what it says on the TIRE?? the sticker was for the factory installed tires...who can say what's on it now.
Re: How much tire pressure?2500 ram truck [Re: cornucopia] #559999
12/22/09 10:51 PM
12/22/09 10:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What's on the tire is the maximum safe pressure not the recommended pressure. That is not what to use but what not to go over.
Re: How much tire pressure?2500 ram truck [Re: stumpy] #560000
12/22/09 11:32 PM
12/22/09 11:32 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
Be careful, if the sticker calls for high pressures for load range E tires and someone put on load range D or LT tires that have a max pressure of 35 or 44, and you inflate to door sticker specs (60 to 80) you will be creating an unsafe condition.
Re: How much tire pressure?2500 ram truck [Re: 69MOPE] #560001
12/22/09 11:51 PM
12/22/09 11:51 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I just had this discussion with a tire dealer when I put new tires on my pick up. Max pressure is around 80#. I run the tires at 65#. The door sticker says to run 55# front and 80 rear. When the previous owner did this he put new tires on at 20K miles. Why would you want less pressure on the tires that have the weight of a diesel engine on them and max pressure on the rear tires with no load on them. I put 35K on my tires keeping them rotated and equal pressure. They are still in great shape. Not trying to argue but it goes against what I was taught in school and the tire dealer agrees with me. The only reason I put new tires on is because I bought new rims for the vehicle. BTW after fighting GM on tire wear issues on our 07 Impala, the service department and alignment shop both advise against the recommended 32# on the door. They both said to inflate to max pressure since the rear has the highway patrol car suspension package now. It has not affected the TPMS yet. Again I am not trying to start an argument.
Re: How much tire pressure?2500 ram truck [Re: Crabra] #560002
12/23/09 07:55 AM
12/23/09 07:55 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
He has the right tires LT not P-metric. Check the door placard to see if you have the recommended tire then inflate to the recommended psi.
Re: How much tire pressure?2500 ram truck [Re: redraptor] #560003
12/23/09 09:15 AM
12/23/09 09:15 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Got it. Thanks I did not see the LT tire size. Thanks
Re: How much tire pressure?2500 ram truck [Re: Posest] #560004
12/23/09 09:28 AM
12/23/09 09:28 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Re: How much tire pressure?2500 ram truck [Re: 69MOPE] #560005
12/23/09 04:07 PM
12/23/09 04:07 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
You would already have an unsafe condition if your using tires that don't meet the load range for the vehicle.
Re: How much tire pressure?2500 ram truck [Re: JeffC] #560006
12/23/09 04:25 PM
12/23/09 04:25 PM
P
Paul_Fancsali Offline
P
Eighty in back will make you need a kidney belt run 65-70 rear 50-55 frt on load range E tire. On full load 80 is acceptable. The door usually staes the recommended tire pressure I take that and add 3-4 in the winter to allow for loss of inflation due to temp loss
Re: How much tire pressure?2500 ram truck [Re: Paul_Fancsali] #560007
12/23/09 08:26 PM
12/23/09 08:26 PM
ohio
67mprfan Online content
67mprfan  Online Content
ohio
I have a 96 ram 2500 when the 1st time i inflated to 80psi the truck rolled as smooth as a car just my 2cts
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
