Fitting cam bearings? #558614
12/20/09 04:43 PM
12/20/09 04:43 PM
Northeast Georgia
47hudson Offline OP
47hudson  Offline OP
Northeast Georgia
My favorite machinist has retired. I tried a new guy I had good luck with in the past, on chevy engines, but left feeling a little uneasy. He had to "fit" my cam bearings. The cam was too tight and would not install and turn. I had to take the block back along with a cam for him to "fit" the bearings? I have never had this issue before so is this just an issue with some blocks or do I need to take my next block down the road? your appreciated.
Re: Fitting cam bearings? [Re: 47hudson] #558615
12/20/09 04:50 PM
12/20/09 04:50 PM
ohio
1Bad440 Offline
1Bad440  Offline
ohio
I had it happen before after the short block was assembled. I always take the cam now
Re: Fitting cam bearings? [Re: 47hudson] #558616
12/20/09 04:50 PM
12/20/09 04:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Pretty common on a BB Mopar...
Re: Fitting cam bearings? [Re: Al_Alguire] #558617
12/20/09 04:58 PM
12/20/09 04:58 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I've had a few SB cam bearing troubles. My new machinist does it a little different than most. He measures the cam bearing bores and claims he finds them often on the small side. He hones any that need attention before installing the bearings. I have had no issues since I started having him do his thing. LOL
Re: Fitting cam bearings? [Re: goldmember] #558618
12/20/09 05:37 PM
12/20/09 05:37 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Many people have never heard of a "bearing knife", or seen one used - but this is very common with a mopar. Sounds like you're in good hands.
Re: Fitting cam bearings? [Re: Mopar_Rich] #558619
12/20/09 06:27 PM
12/20/09 06:27 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
I like to do my own cam bearings and am very careful. You need to lube them up and stay on top of the tool to keep it as close as you can to alignment. Haven't needed to scrape since I've been doing it myself.
And checking the bearings before is inaccurate since the bearings are an interference fit in the block.
The problem is usually mis alignment which can only be fixed by scraping or replacing.
SS/DA 1924
Re: Fitting cam bearings? [Re: 47hudson] #558620
12/20/09 06:52 PM
12/20/09 06:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Alot of shops have a old cam with a slot cut it in
the bearing journals as a cutter blade.... makes
a perfect sizer, put it in and give it a few spins...
I have one myself and spin it with my impact....
perfect
Re: Fitting cam bearings? [Re: MR_P_BODY] #558621
12/20/09 06:57 PM
12/20/09 06:57 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
It is cutting material from the bearing which shouldn't have to be cut.
SS/DA 1924
Re: Fitting cam bearings? [Re: MR_P_BODY] #558622
12/20/09 07:06 PM
12/20/09 07:06 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I've scraped cam bearings over the years and yes,I feel the modified camshaft trick may work fine. In the future I won't have to worry with those tricks,I hope.
Re: Fitting cam bearings? [Re: MR_P_BODY] #558623
12/20/09 07:14 PM
12/20/09 07:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've used the old cam with slotted journals for years, works every time.
Re: Fitting cam bearings? [Re: John_Kunkel] #558624
12/20/09 07:54 PM
12/20/09 07:54 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Not saying it wont work, just saying it is a bandaid for misalignment by the installer
Would you scrape your rod or mains for extra clearance??
SS/DA 1924
Re: Fitting cam bearings? [Re: SSDAcuda] #558625
12/20/09 07:59 PM
12/20/09 07:59 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
What do you think they did in the old motors with poured babbitt bearings? Cut to fit!
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Fitting cam bearings? [Re: SSDAcuda] #558626
12/20/09 08:07 PM
12/20/09 08:07 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Its not a alignment issue IMO, The bearing itself is so wide that once pressed in it would be self aligning. Its a thickness issue thats resolved by honeing/bearing knife or the Kunkle cam fix.
I use the slotted cam fix, works great. This cam bearing problem is common with BB I guess its better to make the bearings a little thick vs a little thin. You can take clearence out but you cant put it back in. mike
Re: Fitting cam bearings? [Re: Sport440] #558627
12/20/09 08:09 PM
12/20/09 08:09 PM
Stealth poster
Stealth poster
Exactly! I made my own cutter cams too and it does the trick!
Re: Fitting cam bearings? [Re: maundmotorworks] #558628
12/20/09 08:23 PM
12/20/09 08:23 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
I guess my street hemis must use the thin bearings
SS/DA 1924
Re: Fitting cam bearings? [Re: SSDAcuda] #558629
12/20/09 08:54 PM
12/20/09 08:54 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Wait a minute, are you onto something? Do they sell thin and thick Cam bearings. Fill us in , mike
Re: Fitting cam bearings? [Re: Sport440] #558630
12/21/09 12:24 AM
12/21/09 12:24 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
FWIW , my mopar mega block had cam bearing journals #2 and #3 .0015" undersized and wouldn't allow the cam to spin because of tight fit. My machinest and I made special mandrels to fit in the nearest bearing bores and align bored the undersized bores to the correct dimensions.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Fitting cam bearings? [Re: Al_Alguire] #558631
12/21/09 12:18 PM
12/21/09 12:18 PM
Northeast Georgia
47hudson Offline OP
47hudson  Offline OP
Northeast Georgia
Thanks guys that's what I was hoping to hear. He mentioned the grooved cam trick but said he could no longer locate his for a Mopar. I feel better now.
Re: Fitting cam bearings? [Re: 47hudson] #558632
12/21/09 01:15 PM
12/21/09 01:15 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
Cure the problem not the symptom!
On my web site I wrote a quick few paragraphs in "Mikes Blog" about "the real real reason why your cam won't turn."
It is a block issue not a bearing issue. Click below to goto my web site.
Mike @MM
Re: Fitting cam bearings? [Re: MuscleMike] #558633
12/21/09 03:28 PM
12/21/09 03:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it's a block problem what did the factory engine plant do to size the bearings?
