Re: Fitting cam bearings?
[Re: 47hudson]
#558616
12/20/09 04:50 PM
12/20/09 04:50 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Pretty common on a BB Mopar...
[Re: Mopar_Rich]
#558619
12/20/09 06:27 PM
12/20/09 06:27 PM
Posts: 872 NJ
SSDAcuda
NJ
I like to do my own cam bearings and am very careful. You need to lube them up and stay on top of the tool to keep it as close as you can to alignment. Haven't needed to scrape since I've been doing it myself. And checking the bearings before is inaccurate since the bearings are an interference fit in the block. The problem is usually mis alignment which can only be fixed by scraping or replacing.
SS/DA 1924
[Re: MR_P_BODY]
#558621
12/20/09 06:57 PM
12/20/09 06:57 PM
Posts: 872 NJ
SSDAcuda
NJ
It is cutting material from the bearing which shouldn't have to be cut.
SS/DA 1924
[Re: John_Kunkel]
#558624
12/20/09 07:54 PM
12/20/09 07:54 PM
Posts: 872 NJ
SSDAcuda
NJ
Not saying it wont work, just saying it is a bandaid for misalignment by the installer
Would you scrape your rod or mains for extra clearance??
SS/DA 1924
[Re: SSDAcuda]
#558626
12/20/09 08:07 PM
12/20/09 08:07 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Its not a alignment issue IMO, The bearing itself is so wide that once pressed in it would be self aligning. Its a thickness issue thats resolved by honeing/bearing knife or the Kunkle cam fix.
I use the slotted cam fix, works great. This cam bearing problem is common with BB I guess its better to make the bearings a little thick vs a little thin. You can take clearence out but you cant put it back in. mike
[Re: SSDAcuda]
#558629
12/20/09 08:54 PM
12/20/09 08:54 PM
Sport440
Canton, Ohio
I guess my street hemis must use the thin bearings
Wait a minute, are you onto something? Do they sell thin and thick Cam bearings. Fill us in , mike
[Re: Sport440]
#558630
12/21/09 12:24 AM
12/21/09 12:24 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
FWIW , my mopar mega block had cam bearing journals #2 and #3 .0015" undersized and wouldn't allow the cam to spin because of tight fit. My machinest and I made special mandrels to fit in the nearest bearing bores and align bored the undersized bores to the correct dimensions. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: MuscleMike]
#558633
12/21/09 03:28 PM
12/21/09 03:28 PM
Posts: 25,813 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If it's a block problem what did the factory engine plant do to size the bearings?
