Anyone have technical data -Edelbrock Street master 440
#558420
12/20/09 12:00 PM
12/20/09 12:00 PM
Posts: 2,506 Northern Pa
GLR
Northern Pa
Hello, I have an old Edelbrock Street Master 440 intake and I would like to know what the RPM range was of this intake..and weather it is a good one for a rebuilt 440 30 over engine with 9.5 to 1 comp with a Hyd. cam someplace around 474-500" lift with a 270-280 dur @50 3:23 rear gears with a 727 automatic transmission with a stock/HP converter
Re: Anyone have technical data -Edelbrock Street master 440
[Re: GLR]
#558421
12/20/09 01:09 PM
12/20/09 01:09 PM
Posts: 4,782 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Hmmmmmmmm runners are curved like the fantastic Holley Street Dominator and not straight like the vintage Torker. Sorry I do not have any usefull info but- If Eedelbrock was copying the Holley SD that shoud be a great manifold up to 6000rpm.
Keep old mopars alive.
[Re: GLR]
#558428
12/21/09 01:48 AM
12/21/09 01:48 AM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
Well, the ports are alot larger on the streetmaster intake than an SP2P intake. I think it was modified a little just under the carb flange it would work alot better for sure.
Roger that .. the ports on the SP2P are big-time smaller ... for better fuel atomization.
If I put a shorter gear in my MH ... I could probably benefit MORE with the SP2P.
[Re: GLR]
#558429
12/21/09 01:33 PM
12/21/09 01:33 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
From what I remember, the application is for RV use. The blockage that is refered to in the intake is to lenghten the runner for torque. End result is idle to 4500 rpm or so. Edelbrock claimed a 20% increase in torque.
The .474 280MP cam pulls strong to 5200 with a performer, iron manifolds, and stock heads.
An upgrade to eddy rpm heads, rpm dual plane intake and tti headers, really wake up the combination to 6,000 plus rpm (5,000 to 6,000 rpm pulls like a small nitrous shot)..., my street 87 octane motor is 9:1 and makes about 390 hp at the rear wheels on a street tune with big fat torque over a broad range.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
