where to get new Flathead 6 carb float #558271
12/20/09 12:17 AM
12/20/09 12:17 AM
Springfield Oregon
badblubeee Offline OP
super gas
super gas
Springfield Oregon
The title line says it all-is there anywhere to get a NEW float for my Carter ball in ball carb? For some reason this cornsqueezins that they call gasoline eats the solder up in my floats and sinks them.I have 2 floats and have repaired them twice(drilled,drained,solded up the hole and then coated 'em with POR 15)but I don't trust them and would really like a new unit.
Oh, this is for my 51 Cranbrook-I've checked the usual parts houses(NAPA,Auto Zone ect) with no luck.thanks for any help,Dave
Re: where to get new Flathead 6 carb float [Re: badblubeee] #558272
12/20/09 12:44 AM
12/20/09 12:44 AM
Re: where to get new Flathead 6 carb float #558273
12/20/09 02:11 AM
12/20/09 02:11 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
what about ceramic coating like on headers ??just an idea
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: where to get new Flathead 6 carb float #558274
12/20/09 05:11 PM
12/20/09 05:11 PM
Springfield Oregon
super gas
super gas
Springfield Oregon
Thanks for the link-I have a catolog on the way as well as a Ply-Do catolog we'll see what they have.
Any other ideas would be welcomed too
Re: where to get new Flathead 6 carb float [Re: badblubeee] #558275
12/20/09 08:17 PM
12/20/09 08:17 PM
You can also swap to a slant 6 carb. It bolts to the flathead 6 intake and the stock flat 6 linkage hooks up to the carb if you drill the hole in the carb linkage just a little bigger. Factory slant 6 jetting is fine.
Re: where to get new Flathead 6 carb float #558276
12/22/09 09:32 AM
12/22/09 09:32 AM
moparx Online content
moparx  Online Content
i've done this swap before, and as stated, it works great ! plus, it's super easy to get kits and parts. well worth thinking [and doing !] about !
Re: where to get new Flathead 6 carb float [Re: moparx] #558277
12/22/09 09:16 PM
12/22/09 09:16 PM
Springfield Oregon
super gas
super gas
Springfield Oregon
WOW-that would be awsome,I just happen to have a shelf devoted to slanty carbs! I have always had a slant powered rig of some sort in my collection since 1972. Have a 63 Valiant and a 76 Duster right now.thanks for the info-Dave
Re: where to get new Flathead 6 carb float--UPDATE-- [Re: badblubeee] #558278
07/19/10 11:49 PM
07/19/10 11:49 PM
Springfield Oregon
super gas
super gas
Springfield Oregon
Just thought I'd updaate this in case anyone else could use this info. After endless searching and many breakdowns I came up for a fix for the numorous sinking floats in my carb.I bought a tank sending unit float for a 66 Mustang and transfered the needle valve tab from the original float to it.The Mustang float is the same diamenter and about 1/2 inch shorter in length than the original but seems to work fine. Now I can move on to something else like maybe driving the ol' coupe.
