Re: Let's see your k-member carts
[Re: sharpie]
#557835
12/19/09 02:05 PM
12/19/09 02:05 PM
Posts: 283 N.E. England
Roppa440
super street
super street
N.E. England
Really simple wooden frame. Possibly could have had some better castors but these ones I had in my garden shed did the job.
2002 Chevrolet Corvette 5.7 LS1
2011 Alpha Romeo Giulietta Veloce 1.6 JTD
Because running a Mopar in the UK is getting TOO expensive!!
[Re: Roppa440]
#557836
12/19/09 02:07 PM
12/19/09 02:07 PM
Roppa440
super street
super street
N.E. England
I fitted the trans at a later date so I only needed one to fit the engine and K-frame. Here it is having the body lowered over it. The headers were a tight fit between the frame rails but it did fit.
[Re: sharpie]
#557837
12/19/09 02:07 PM
12/19/09 02:07 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Hi Brian, just went through that sort of thing last summer. Just get some square stock (like trailer hitch size), weld up a cradle for the "K" frame. Put some casters on it, then make up a flat stock metal with an adjuster length of square stock welded on it (to attach to the area of the trans cross member). At the bottom weld a caster so the trans will role with the engine. To take the whole thing out as an assembly (eng, trans, "K" member, and suspension)just unbolt the four main "K" member to frame bolts and lift the car off. Let me know if you need help. Mike
The wood thing looks good too.
[Re: 64Post]
#557840
12/19/09 02:23 PM
12/19/09 02:23 PM
Roppa440
super street
super street
N.E. England
Another simple wooden one. Buddy of mine.
[Re: Roppa440]
#557841
12/19/09 02:59 PM
12/19/09 02:59 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Carts?? We don't need no stinking carts !! When in a crutch, use one. . . . Troy getting parts for his Hemi Dart clone.
