Re: 323 gear
[Re: joedust451]
#556507
12/22/09 12:16 AM
12/22/09 12:16 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
[quote you'll be quite satified.
Yeah, if you send my carb parts from 2 plus years ago back to me.............................
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 323 gear
[Re: Pentastar440]
#556508
12/22/09 08:39 AM
12/22/09 08:39 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
ok I have a Fram Filter on it now. I'm changing the old tomorrow. Oil Filter recommendations?
Ditch the Fram , try something like NAPA Gold .
which are a rebranded wix....same with the carquest premiums. Purolators are also good filters, and the cheaper carquest, and I think the napa silvers are purolators.
if you want to up the cam a bit, I'd look at a comp XE268 or a lunati voodoo 60302 for your stock converter and tall gears. you'll need to change the valve springs to comp 916's.
as far as the speedo, multiply the indicated by 2.76/3.23, or .85 to get acutal speed. if your speedo was accurate with the 2.76's, an indicated 150=128 mph with the new gears.
