Page 3 of 3 1 2 3
Re: 323 gear [Re: joedust451] #556507
12/22/09 12:16 AM
12/22/09 12:16 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[quote you'll be quite satified.
Yeah, if you send my carb parts from 2 plus years ago back to me.............................
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 323 gear [Re: Pentastar440] #556508
12/22/09 08:39 AM
12/22/09 08:39 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
ok I have a Fram Filter on it now. I'm changing the old tomorrow. Oil Filter recommendations?
Ditch the Fram , try something like NAPA Gold .
which are a rebranded wix....same with the carquest premiums. Purolators are also good filters, and the cheaper carquest, and I think the napa silvers are purolators.
if you want to up the cam a bit, I'd look at a comp XE268 or a lunati voodoo 60302 for your stock converter and tall gears. you'll need to change the valve springs to comp 916's.
as far as the speedo, multiply the indicated by 2.76/3.23, or .85 to get acutal speed. if your speedo was accurate with the 2.76's, an indicated 150=128 mph with the new gears.
2017 Grand Cherokee Overland
Re: 323 gear [Re: Von] #556509
12/24/09 01:14 AM
12/24/09 01:14 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
there is a roaring in the rear end at coast or whenever you don't press the gas. The guy that build the rear end said it can be adjusted and take it easy til he can get to it. It's a 742 case. What did he do wrong? Just curious
Re: 323 gear [Re: roy2345] #556510
12/24/09 01:33 AM
12/24/09 01:33 AM
PA
U
unclemike Offline
unclemike  Offline
U
PA
Sounds like a bad pinion bearing.
2" inch exhaust?
Who put that on?
If it was a shop that uses a shoe bender the curves are way less than 2" cross section. Check Jeg, Summit, TTI and others for a decent mandrel bent system. Go for 2.5" unless you want to terrify the ricers, then look at the 3" systems out there.
Having had a 350 hp New Yorker 440 in a 1964 Savoy and a 365 hp in a 1968 GTX I can say there is a world of difference between the two as far as power output goes.
Re: 323 gear [Re: unclemike] #556511
12/24/09 09:33 PM
12/24/09 09:33 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
OK will this tear up while driving?
Re: 323 gear [Re: roy2345] #556512
12/24/09 09:40 PM
12/24/09 09:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it is the pinion bearing it will tear up the rearend when it goes. Bad news. Best bet is to put the rear up on jack stands and yry to move the rear end yoke upp and down by hand. If it moves it's bad. You can also turn the driveshaft with the trans in neutral to see if you feel any grinding at the yoke. Then if you're still not sure you can run the car in gear and listen at the axle housing.
Re: 323 gear [Re: stumpy] #556513
12/24/09 09:45 PM
12/24/09 09:45 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
how could that be bad when it was rebuilt with new bearings and seals? Curious
Re: 323 gear [Re: roy2345] #556514
12/24/09 09:49 PM
12/24/09 09:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Maybe it wasn't put together correctly. It does happen.
Page 3 of 3 1 2 3
