Re: 1948 B-1-F Engine number on title instead of Serial
[Re: lunacy]
#555774
12/17/09 12:07 PM
12/17/09 12:07 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Before you remove the engine or strip the truck down, talk to the local motor vehicles and the highway patrol. There was no set way to record the serial numbers back then, so sometimes the body number was used, sometimes the engine number. There was a guy on the HAMB that had the car inspected and a new title issued with the body number. He needed a new title in his name, and he explained that he would be replacing the engine (I'd avoid mentioning a newer engine) so he wanted the title to reflect the body number. Research the state laws and see if you can provide them with copies. Show them you aren't trying to pull a fast one, and they should work with you, but do it while all the numbers are still together....
[Re: PocketThunder]
#555776
12/18/09 05:54 PM
12/18/09 05:54 PM
Posts: 435 Austin, TX
lunacy
Austin, TX
And dont forget to post up pictures of the truck for us!
Posted some pics up a few months ago when I first got it, finally getting around to messing with it.
Here they are again.
[Re: RodStRace]
#555777
12/20/09 01:03 AM
12/20/09 01:03 AM
Posts: 5,285 South Carolina
FM3_1970
South Carolina
RodStRace is right, I think. Before 1956, Texas used engine numbers in titles for most vehicles, then went to chassis numbers (1949 for Fords). Think California changed over about then, too. As long as you have the original motor in the truck, and the number on it matches the title, you shouldn't have any problems getting a new title. Maybe they'll let you use the chassis number (do a "title correction"), but you'll probably have to get a new, state assigned VIN, and a new VIN plate on the door frame. Doesn't sound like you're doing a resto, so that shouldn't bother you. Here's a link to the TexasDOT website page for vehicle title publications: http://www.txdot.gov/txdot_library/drivers_vehicles/publications/title.htm The downloadable Motor Vehicle Title Manual should tell you what the forms and procedures are.
[Re: FM3_1970]
#555778
12/20/09 02:09 AM
12/20/09 02:09 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
gonna shoe horn a cummins in there? wow,,,can you say move that fire walll,,,kool project,,,we put a cumming in a 1 ton 1975 dodge van,learned a lot then, wasnt my van,,but the van rotted away the low mileage cummins is sitting under a bench where it will be for ever i suppose,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#555780
12/20/09 02:15 AM
12/20/09 02:15 AM
lunacy
Austin, TX
Planning on a 90's 1 ton frame/drivetrain swap. Based on some rough measurements it looks like it will fit with some firewall clearance, but even the intercooler will drop between the front fenders. Quote:
[Re: lunacy]
#555781
12/20/09 02:32 AM
12/20/09 02:32 AM
fstfish66
levittown pa
nice,,manual or auto ?? dually ?? intresting project,,,
