I bought a 48 Dodge 1-1/2 ton flat bed a while back. The title has the engine number on it T14817406, not the actual serial number listed on the cab. The motor that is in it is seized up and the truck is destined for a cummins swap anyway. Do any of you know if I can get this changed on the title or how do I go about getting it right so I can get it legal once it has a new motor?
