Thanx guys....
What Im tring to find out is if I can get this engine to make similar HP but more TQ for a dual purpose street/strip A body.
If MM can help with a CNC program that will enhance air speed thru the port with a slightly different cross section it would help TQ and not affect HP too much ?
Short of stabbing is a custom longer arm crank
and the the issuess it'll create with the 9" deck....what other options are there to beef up TQ and try to maintain similar HP output?
Rat
