Porting P7 heads qun... #555306
12/16/09 11:31 AM
12/16/09 11:31 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Guys anyone know who can port a set of P7 heads that are raw/unported/as cast?
Im thinking more along the lines of "max air speed / cyl fill" head for a street /strip application as opposed to the CNCd 400cfm + as they often come.
any thoughts on this and can anyone point me to some one who knows/P7s and does this?
Ryan....?
Re: Porting P7 heads qun... [Re: LAD 524] #555307
12/16/09 01:18 PM
12/16/09 01:18 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Dave Weber @ Modern Muscle has several CNC programs for the P7's, I think Modern may have one as well. I would check with them depending on what you're trying to do with them.
Re: Porting P7 heads qun... [Re: RyanJ] #555308
12/16/09 01:29 PM
12/16/09 01:29 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thanx for the heads up Ryan - where are they located?
Thanx...
Re: Porting P7 heads qun... [Re: RyanJ] #555309
12/16/09 01:31 PM
12/16/09 01:31 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Also ck with Curtis Boggs he post alot over at speedtalk.com
Re: Porting P7 heads qun... [Re: LAD 524] #555310
12/16/09 01:33 PM
12/16/09 01:33 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Re: Porting P7 heads qun... [Re: RyanJ] #555311
12/16/09 01:40 PM
12/16/09 01:40 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thanx guys....
What Im tring to find out is if I can get this engine to make similar HP but more TQ for a dual purpose street/strip A body.
If MM can help with a CNC program that will enhance air speed thru the port with a slightly different cross section it would help TQ and not affect HP too much ?
Short of stabbing is a custom longer arm crank
and the the issuess it'll create with the 9" deck....what other options are there to beef up TQ and try to maintain similar HP output?
Rat
Re: Porting P7 heads qun... [Re: LAD 524] #555312
12/16/09 01:51 PM
12/16/09 01:51 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Thanx...
http://lmgtfy.com/?q=modern+muscle
Re: Porting P7 heads qun... [Re: aarcuda] #555313
12/16/09 02:00 PM
12/16/09 02:00 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Did that just B4 Ryan posted....its 5AM here....
sheesh....
Rat
Re: Porting P7 heads qun... [Re: LAD 524] #555314
12/16/09 02:40 PM
12/16/09 02:40 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
ya, i was just messing with ya. someone sent that link to me once and i just had to use it
