Re: Who makes coil springs for old cars?
[Re: migsBIG]
#555260
12/16/09 08:44 PM
12/16/09 08:44 PM
Posts: 15 N.E. Ohio
renegade0131
N.E. Ohio
Valley Spring Works 340 Industrial Way Dixon, CA 95620-9206 (707) 678-3944
[Re: poorboy]
#555262
12/21/09 10:46 AM
12/21/09 10:46 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Too bad you arent close.I have a 41 that the kid is stripping.Has great springs and all the suspension.Rocky
Chrysler Firepower
[Re: migsBIG]
#555264
12/24/09 02:49 PM
12/24/09 02:49 PM
therocks
Niles , Ohio
Its covered with snow now.He was talking about getting rid of the whole car soon.He is supposed to be getting an M37 Dodge truck.So something has to go.His other brother is still stripping his 66 Charger too.Rocky
Chrysler Firepower
[Re: cuhemida]
#555266
12/26/09 03:02 AM
12/26/09 03:02 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
i may be intrested in a pair of front spindles if any one has a set or knows what years may be the same as a 1940 dodge,,,mine were adapted before i bought the car by master power brake,,and have 11 inch chevelle rotors, im going to check and see if they have enough room to be redrilled for the mopar /ford/amc pattern,,incase i ever change rims,,ide like to go to a radir wheel,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: poorboy]
#555268
12/29/09 10:11 AM
12/29/09 10:11 AM
fstfish66
levittown pa
from what i understand there has been work done to the spindles by master power brake to accept the GM rotors,,when i get it back in the garage i plan to look and see if i can tell what may have been done,,i could call master power to find out i would think,,but some how i woul dlike to get a 4 1/2 bolt circle,,i have a bolt circle checker,,has all types of patterns on it,, if there is enough meat, i was thinking i could slip it down on the GM pattern and see if theres enough room to drill thru the mopar pattern,,it would be perfectly centered then,,
[Re: RodStRace]
#555270
12/30/09 12:16 AM
12/30/09 12:16 AM
Posts: 11 Sandy, Utah
Robert R
Sandy, Utah
Depending on the year of the car you are building Eaton Detroit Spring can supply you with the springs. I am building a 50 Suburban Wagon and my dropped springs came from them. My front end is about done with dropped uprights (the equivalent of dropped spindles), disc brakes and rack and pinion steering. If your car is close to the same year I can give you the suppliers of all the parts. The disc brakes use Volare rotors and Chevy calipers, I would have liked Mopar but they are hard to mount, Chevy is easy. We are going to run a 340 with injection and a A518 overdrive auto. The rear will be brought up with a Ford 8.8 rear with disc brakes and 3.73 limited slip differential.
Currently building a 1950 Plym Suburban '70 340/A518 combo
1965 Dodge Dart Driver
1962 Jeep FC-170
1956 Nash Metropolitan
[Re: Robert R]
#555271
12/30/09 02:55 AM
12/30/09 02:55 AM
fstfish66
levittown pa
dropped uprights and new full size coils to go on my 40 coupe, this comming year,,,any pics??
[Re: RodStRace]
#555272
01/08/10 12:39 PM
01/08/10 12:39 PM
fstfish66
levittown pa
once i get to it,, i would think that would be the simplest thing to do ,,,im not sure how the studs are held in to the GM rotor,,,pressed i would hope,,,i currently have dual pattern rims,,that i do like,, but i keep thinking it may look kool with radir rims,,
[Re: Robert R]
#555273
01/08/10 12:43 PM
01/08/10 12:43 PM
fstfish66
levittown pa
40 dodge from what ive seen your front suspension looks to be about the same stuff as my 40..i have fat man rack and pinion,,master power brakes, it was like that when i bought the car,,,master power reworked the spindles to accept the chevell rotors,,only kit they had at that time i would guess,,i would of searched till i found mopar/ford rotors kit,, the coils have been cut to give it its stance,,but it has no front suspension travel,,,so rides worse then my dodge 3/4 ton truck ,when on a bumpy road,,,so dropped spindles and coils this year when i get to it,,didnt know eaton had springs made for the drop good to know,,thanks
