Page 1 of 3 1 2 3
FYI Steering shaft dissection101 #55509
03/30/08 06:11 PM
03/30/08 06:11 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline OP
super gas
super gas
Not sure if this topic was ever put to rest about the so called "pins" in a collapsible steering shaft but thought it
would be good to see some pictures of one I had to repair today. The first picture shows bent shafts I received that
could not be saved from 2 different columns. Luckily the bottom of one and the top of the other were okay so I could make a
good one from 2.
Jules
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55510
03/30/08 06:14 PM
03/30/08 06:14 PM
super gas
super gas
Second picture shows the 2 good halves that will be mated to make a good one.
You can see where the so called "pins" come from. The 2 holes on either side of
the flat tube shaft is where plastic is injected to fill the cavity that is on the solid
shaft.
Jules
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55511
03/30/08 06:15 PM
03/30/08 06:15 PM
super gas
super gas
Another
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55512
03/30/08 06:17 PM
03/30/08 06:17 PM
super gas
super gas
This last picture shows the plastic removed from the cavity.
In order to replace the broken pins, you would have to separate both halves ,
remove the excess plastic and inject new plastic. Make it ooze out of both sides
and voila the shaft is intact again.
Jules
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55513
03/30/08 06:19 PM
03/30/08 06:19 PM
super gas
super gas
Just as a side bar. Separating the two halves required a sledge hammer.
If you were ever worried about the 2 halves coming apart on their own, forget it!
Even though they may slide in and out they will not come out easily passed the plastic
injected area.
Jules
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55514
03/30/08 06:42 PM
03/30/08 06:42 PM
N
NITROUSN Offline
NITROUSN  Offline
N
We used to fix them when they were collapsed. Mopar used to have a kit. Do to liability the kit was cancelled.
Do you inject plastic back in when you reassemble?
Re: FYI Steering shaft dissection101 [Re: NITROUSN] #55515
03/30/08 07:53 PM
03/30/08 07:53 PM
super gas
super gas
I will. It will not be plastic though. Epoxy with a syringe.
Jules
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55516
03/30/08 08:50 PM
03/30/08 08:50 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Jules
What do you prefer for an epoxy? It would have to be very liquid to flow.
Re: FYI Steering shaft dissection101 [Re: NITROUSN] #55517
03/30/08 09:41 PM
03/30/08 09:41 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
This is great Jules, I've never taken one apart. But I'm wondering is there a coresponding recessed cavity in the female shaft?
Norm
Re: FYI Steering shaft dissection101 [Re: gygeneral] #55518
03/30/08 09:46 PM
03/30/08 09:46 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Norm
Not as I recall. The excess that flows out the holes acts as a shear point. If there was to much teflon in a larger cavity it would not shear as designed. Even using epoxy or ant repair for that matter is a gray area libility wise. But what is one to do when parts are so hard to find.
Re: FYI Steering shaft dissection101 [Re: NITROUSN] #55519
03/30/08 09:50 PM
03/30/08 09:50 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
So all there is , is two of those small plastic pins holding the two sections? Wow!
Re: FYI Steering shaft dissection101 [Re: gygeneral] #55520
03/30/08 10:11 PM
03/30/08 10:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Why would you need any more? Its designed to collapse on impact.
Re: FYI Steering shaft dissection101 [Re: NITROUSN] #55521
03/31/08 07:06 AM
03/31/08 07:06 AM
super gas
super gas
Actually it's more than just pins. The plastic fills whatever gap there may be between the tube and the solid shaft.
This adds friction. Trust me I needed to hammer away at it to separate them. In an accident the forces are great and the shaft
would collapse. NITROUSN, what would you suggest other than epoxy?
Jules
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55522
03/31/08 09:31 AM
03/31/08 09:31 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Thanks for the info.
I'm currently going from manual steering to power in my 1971 Challenger.
From what you see will it be possible to collapse my longer manual steering shaft by hammering the shaft in and make it work on a power steering box?
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55523
03/31/08 09:54 AM
03/31/08 09:54 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I am not sure I would use epoxy either. I think it would bond the two halves together. What about the cast resin stuff that is liquid until hardens?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: FYI Steering shaft dissection101 [Re: RoadRunner] #55524
03/31/08 10:52 AM
03/31/08 10:52 AM
super gas
super gas
KillerBee -- no problem, however you won't be able to line up the pin holes with the cavities on the solid shaft .
Cast resin sounds good also.
Re: FYI Steering shaft dissection101 [Re: RoadRunner] #55525
03/31/08 11:23 AM
03/31/08 11:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
cast resin ????
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55526
03/31/08 11:26 AM
03/31/08 11:26 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Jules
Jules I really dont know. For the most part what you are doing will be fine. Your work always looks excellent by the way. If one was to know exactly what the factory used you might be able to find it and use it. Most likely it was a procedure that pulled the liquid into the void. Some sort of vacuum to pull it through to eliminate voids. The repair kits were like a loctite product. You left the teflon on the shaft. Marked the shafts for assembley. Used a primer or promoter on the two areas and put a liquid around the teflon and quickly slid the shafts togeather to the correct length. Then There was a cure time which was like 24 hours. Like I said they quit marketing the kit for liability. For now I would keep doing what you are. I hear of others bolting, riviting, and even welding the shafts togeather.
Re: FYI Steering shaft dissection101 [Re: NITROUSN] #55527
03/31/08 01:19 PM
03/31/08 01:19 PM
super gas
super gas
" I hear of others bolting, riviting, and even welding the shafts togeather."
Thanks for the input guys.
I'll stick to my method for now.
Jules
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55528
03/31/08 01:35 PM
03/31/08 01:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jules
my father had to be cut out of a 65 mustang that he was pinned in when he tangled with a 54 olds , it wasn't pretty .
Page 1 of 3 1 2 3
