High 10's in a b body with a small block? #553728
12/14/09 02:27 PM
12/14/09 02:27 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Is this doable with a stock block?
Re: High 10's in a b body with a small block? [Re: Blown61] #553729
12/14/09 02:29 PM
12/14/09 02:29 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Be more specific. How heavy is the car, is it a street/strip car, etc.
Re: High 10's in a b body with a small block? [Re: sixpakdodge] #553730
12/14/09 02:51 PM
12/14/09 02:51 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
street strip, 3800
Re: High 10's in a b body with a small block? [Re: Blown61] #553731
12/14/09 03:08 PM
12/14/09 03:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
anything is possible but a better question is why? when you can get a BB to do it much cheaper and easier and you won't have to spinn the doo doo out of it.
Coming soon!!!!
Re: High 10's in a b body with a small block? [Re: Blown61] #553732
12/14/09 03:11 PM
12/14/09 03:11 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
street strip, 3800
Probably not going to happen with a stock block A/LA. You would have to make at least 600 horsepower to get all that weight moving.
Re: High 10's in a b body with a small block? [Re: Blown61] #553733
12/14/09 04:16 PM
12/14/09 04:16 PM
AndyF Online content
AndyF  Online Content
Sure you can do that. Can do it with cast iron heads and a ThermoQuad if you had to. Just depends if you're willing to work that hard or not.
Re: High 10's in a b body with a small block? [Re: AndyF] #553734
12/14/09 05:13 PM
12/14/09 05:13 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
That is something you never see B body with a small block and then running 10s that would be awesome
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: High 10's in a b body with a small block? [Re: AndyF] #553735
12/14/09 05:25 PM
12/14/09 05:25 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Yep, some determination and 510 HP.
Re: High 10's in a b body with a small block? [Re: 65signet] #553736
12/14/09 10:58 PM
12/14/09 10:58 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I'll bet RyanJ's twin turbo w8 superbee will rip off a lot faster times than high 10s.
Re: High 10's in a b body with a small block? [Re: b1dartsport] #553737
12/15/09 12:26 AM
12/15/09 12:26 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Why so heavy? What kind of B boby are we talking about?
Re: High 10's in a b body with a small block? [Re: scatpacktom] #553738
12/15/09 09:31 AM
12/15/09 09:31 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not really my 67 coronet was 3850 w/ me and 1/2 tank of gas as raced. a 68-70 B-body is going to be just as heavy I'd think.
Coming soon!!!!
Re: High 10's in a b body with a small block? [Re: Mr.Yuck] #553739
12/15/09 09:39 AM
12/15/09 09:39 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
The coronet and my plump self with 1/2 tanks of gas weigh in at a healthy 3940 lbs!
Mike\
PS truth be told I could probably stand to do some wieght reduction.
1969 Dodge Dart Swinger
Re: High 10's in a b body with a small block? [Re: MikeyT] #553740
12/15/09 10:18 AM
12/15/09 10:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Mike\
yeah I am around 185 and I think this 70+me+1/2 tank is going to be close to that if not more. thses 70's are at least 6" longer than 68-69's. and they have that BIG wrap around bumper.
Re: High 10's in a b body with a small block? [Re: Blown61] #553741
12/15/09 10:51 AM
12/15/09 10:51 AM
Az
Crizila Offline
Crizila  Offline
Az
According to my trusty Moroso power Calculator ( used improperly of course ), with your weight ( 3800 lbs.) you will need to make 535HP at the rear wheels to run 10.80. That would be a little over 600HP at the flywheel. That would be a mighty stout normally asperated 360 - basically not streetable - IMO. A 150 HP nitrous system would probably allow you to drive it around the block.
Fastest 300
