Header Collector Help #553706
12/14/09 02:20 PM
12/14/09 02:20 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
With all the options avaliable for header collectors I'm still undecided. I'm updating a set of Hooker Super Comp headers w/new collectors. At first merge collectors seemed the way to go, but then I get to thinking about the 4-2-1 scavenger collectors. The only problem is they have smaller final tubes(2 1/2 or 2 3/4) I'm thinking I can put a reverse cone at the end of the 2 3/4 scav. collector and make that work, but I don't know where to put the crank case evac tube(3 or 4 in. back?) Do the scavenger collectors (4-2-1) work that much better?
Yeah, it's got a smallblock.
Re: Header Collector Help [Re: 340B5] #553707
12/14/09 03:07 PM
12/14/09 03:07 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Don't see any on race cars. You see a lot of merges, though.
Re: Header Collector Help [Re: 340B5] #553708
12/14/09 11:28 PM
12/14/09 11:28 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I would go with the merge. Look on E-bay. I picked up these stainless ones for $75.
Re: Header Collector Help [Re: PLUM BAD] #553709
12/15/09 07:40 AM
12/15/09 07:40 AM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Thanks. And thanks for taking time to post pics
Re: Header Collector Help [Re: 340B5] #553710
12/15/09 08:44 AM
12/15/09 08:44 AM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: Header Collector Help [Re: Butch] #553711
12/15/09 09:58 AM
12/15/09 09:58 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Post deleted by Defbob [Re: GomangoCuda] #553712
12/15/09 02:15 PM
12/15/09 02:15 PM
Re: Header Collector Help #553713
12/15/09 03:30 PM
12/15/09 03:30 PM
sg66mopar Offline
sg66mopar  Offline
Scott Koffel said pretty much the same thing as HEMIFRED when I talked to him about the headers I need to build for my new B1 heads. Unless you can get a killer deal somewhere or you really need every last HP the merge collectors just aren't worth the money. I'm running Super Gas and brackets and my new combo should be around 1000 HP so that theory works for me.
Re: Header Collector Help [Re: sg66mopar] #553714
12/15/09 03:34 PM
12/15/09 03:34 PM
sg66mopar Offline
sg66mopar  Offline
BTW, I've run the 4-2-1 Scavenger collectors from Flowmaster on my car for the last 15 years or so. I've always felt they didn't come close to the HP increase Flowmaster claimed. I have no intention of using them on my new setup.
Re: Header Collector Help [Re: sg66mopar] #553715
12/15/09 03:59 PM
12/15/09 03:59 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Post deleted by Defbob [Re: sg66mopar] #553716
12/15/09 04:12 PM
12/15/09 04:12 PM
Re: Header Collector Help #553717
12/15/09 09:57 PM
12/15/09 09:57 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Thanks for all the responses. Welding a cone in the headers is an old trick worth a few extra HP. It's a lot of trouble for a few hp, but I want to get rid of those flanges that keep catching on my trailer too. One website not mentioned above is ssheaders.com, they have a decent tech article on headers. Sorry about the hit n run post; working lots of hours.
Re: Header Collector Help [Re: 340B5] #553718
12/15/09 11:06 PM
12/15/09 11:06 PM
sg66mopar Offline
sg66mopar  Offline
If you have a Racer's discount with Summit you can get the Hooker Super Comp. merge collectors for $165 a pair. Never had experience with them so I can't say if they actually do their job as advertised.
Re: Header Collector Help #553719
12/16/09 08:36 AM
12/16/09 08:36 AM
GomangoCuda Offline
GomangoCuda  Offline
Some sources.
http://www.spdexhaust.com/pdfs/02-11_Merge_Collectors.pdf
http://www.burnsstainless.com/MergeCollectors/mergecollectors.html
http://www.stainlessheaders.com/mergecollectors
http://www.perfweldheaders.com/compmerg.html
http://www.coneeng.com/collectors.html
all are very expensive and IMHO not worth it for the average racer or bracket car
I agree completely. These are only for max effort, cost is no object efforts like Prostock, Comp eliminator, and SS/AH. But a few of these sites do have some interesting info on the subject of headers and collectors.
Re: Header Collector Help [Re: 340B5] #553720
12/16/09 09:34 AM
12/16/09 09:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Most all over the counter headers are designed for
a street version engines, the primary tubes are long
and the collectors are way too short and usually too
small in diameter. A set of headers needs to be designed
for the engine... primary tube diameter, length and
collector diameter and length. A merge collector isnt
a one size fits all, cone shape and length mean ALOT.
Also if you run a exhaust, the extension pipe going
to the muffler is part of the collector(any length
before a expansion area)... collectors go in length
of multiples for tuning... if 18" is the best, then
36" is the next tuning length(sound wave)
Re: Header Collector Help #553721
12/16/09 11:36 AM
12/16/09 11:36 AM
Los Alamitos, CA
coneeng Offline
coneeng  Offline
Los Alamitos, CA
Some sources.
Collector kits start at $115 in MS and $150 in SS - that's for 2 collectors including your choice of transition cones.
http://www.coneeng.com/exhaust_system_kits.html
Re: Header Collector Help [Re: coneeng] #553722
12/16/09 10:13 PM
12/16/09 10:13 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Wow....glad I revisited this post, and welcome to Moparts. I'm on a tight budget, but I don't mind a little fab work and your prices sound good. I'll visit your web site and most likely give you a call when time permits.
Post deleted by Defbob [Re: 340B5] #553723
12/16/09 10:28 PM
12/16/09 10:28 PM
Re: Header Collector Help #553724
12/16/09 10:41 PM
12/16/09 10:41 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm using the el cheapo hooker merge collectors. don't know if theres any gains in hp but it's sure easy yo install & remove the tubes if i need to do do any work. i've recycled the collector onto my second set of headers so they're handy to have.
Re: Header Collector Help #553725
12/17/09 11:31 AM
12/17/09 11:31 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
plus a week of welding.
bet there's not enough increase to warrant cost and assembly time for 99.9% of racers here because the rest of the head is not tuned for optium results
There are some serious racers on this board. Maybe 99.5% would be more accurate?
