How to mount Space Saver tire? #553647
12/14/09 11:55 AM
12/14/09 11:55 AM
NY
70440+6bbl Offline OP
NY
I repainted a space saver rim and need to have the original F78-14 BFG tire mounted back on it. I found some factory warning literature where it is stated NOT to use use compressed air and to only use the inflator cannister... Has anyone done this before without damaging the tire?
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: How to mount Space Saver tire? [Re: 70440+6bbl] #553648
12/14/09 11:57 AM
12/14/09 11:57 AM
NY
NY
The Space-Saver should only be inflated with the special canister provided. Never use an air hose. The canister is good for one use only; a new canister must be obtained for future use.
Follow the approved mounting and use instructions.
As early as possible, remove the Space-Saver and replace it with a normal tire.
The Space-Saver is a load range B tire and should never be inflated past 32 psi.
Because of its construction, the Space-Saver tire beads may appear to be improperly seated on the wheel. This is normal. Do not attempt to seat the beads by adding more air.
To deflate the tire, remove the valve stem and fold the tire around the rim.
No attempt should be made to remove the Space-Saver tire from the rim or to repair the tire.
Figure 4 Space-saver spares required special handling to preserve their usefulness
Re: How to mount Space Saver tire? [Re: 70440+6bbl] #553649
12/14/09 02:15 PM
12/14/09 02:15 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
well it worked for me,i pumped air in it to make it seat and then i inflated it again and it schrunk back to its small size.BUT,i was warned before i did it cause a friend just for fun pumped air in his space saver and it didnt go back to the small size,maybe it was dryed out or something. good luck
Re: How to mount Space Saver tire? [Re: cuda-sweden] #553650
12/15/09 12:39 AM
12/15/09 12:39 AM
NY
NY
Thanks Cuda-Sweden, anyone else have any experience?
Re: How to mount Space Saver tire? [Re: 70440+6bbl] #553651
12/15/09 01:18 AM
12/15/09 01:18 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I would like to know as well. I also have a refinished rim, and need to put the tire back. The shop that removed it for me claimed that they can't re-install it properly. Before they removed the tire, they did inflate it with compressed air, and it did collapse back to normal without any problem.
Re: How to mount Space Saver tire? [Re: Barnabas_Kriss] #553652
12/15/09 08:56 AM
12/15/09 08:56 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
I have done dozens of restorations on space savers and this is what I have learned.
You can easily inflate the tire with air and then deflate it and the tire will return to its'
original shape. Sometimes it takes a good 10 minutes. HOWEVER, if the tire has been inflated for a
long time and /or it has been run on, it will NOT return to its shape. The tire can be removed from the rim and
installed back on BUT it is murder trying to get it back on. You must use a regular tire machine. Not today's
mag wheel machines that do not touch the rims.It will be very hard to get back on and when I do them done it takes 3
guys and loads of lubricant to succeed. I believe the problem is that the rubber is so old that it has lost its flexibility and thus
it does not want to stretch and co-operate. Heating the tire does not help much either. We tried that. Keep in mind
that your experience may vary due to the condition of your particular tire.
Jules
Re: How to mount Space Saver tire? [Re: JulesdaWiperman] #553653
12/15/09 08:58 AM
12/15/09 08:58 AM
super gas
super gas
2
Re: How to mount Space Saver tire? [Re: JulesdaWiperman] #553654
12/15/09 09:53 AM
12/15/09 09:53 AM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
Is the rim of a space saver different than a regular rim?? I have a gm rim and tire that I would like to change over to a mopar bolt pattern ?? Thanks
Re: How to mount Space Saver tire? [Re: JulesdaWiperman] #553655
12/15/09 10:06 AM
12/15/09 10:06 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Jules,
Do you paint the rim before or after mounting the tire?
Re: How to mount Space Saver tire? [Re: RTshaker] #553656
12/15/09 12:42 PM
12/15/09 12:42 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
thats what i did,pontiac aluminum space saver wheel,cut the rim in half with a vinkelslip, removed the tire and mounted it on a regular junk yard 14" rim.simsalabim a look alike space saver wheel,but with good year tire.but i can live with that until i ran into a bf-goodrich.overandout
Re: How to mount Space Saver tire? [Re: cuda-sweden] #553657
12/15/09 02:41 PM
12/15/09 02:41 PM
super gas
super gas
Snoopy,
I primer the rim in black first and then mount the tire.
After the tire is on I tape it off and then paint the rim gloss black.
I cannot do it before hand because the process of installing the tire
would badly scratch the edge of the rim.
Jules
Re: How to mount Space Saver tire? [Re: JulesdaWiperman] #553658
12/15/09 04:33 PM
12/15/09 04:33 PM
Snoopy Offline
Snoopy  Offline
Jules,
That was the way I was planning on doing mine, just wanted to check with the Master.
Re: How to mount Space Saver tire? [Re: Snoopy] #553659
12/15/09 10:04 PM
12/15/09 10:04 PM
NY
NY
Hi Jules,
I had a local tire shop put the tires back on (I am doing two '70 space savers), he got them ON the rim with no problem, but they are not centered and the beads do not sit right... Is that where the issue lies with these tires? I will bring them back to him and tell him to use lots more lube if you think that is the problem.
Re: How to mount Space Saver tire? [Re: 70440+6bbl] #553660
12/15/09 11:04 PM
12/15/09 11:04 PM
super gas
super gas
Take the wheel in hand on each side and flat drop it on the tread several tires. Do the whole circumference of the tire
like that. Try to inflate it after that.
If it still does not hold air. Do it again.
I have always succeeded in inflating it and hence centering the tire on the rim in this fashion.
Jules
Re: How to mount Space Saver tire? [Re: JulesdaWiperman] #553661
12/15/09 11:15 PM
12/15/09 11:15 PM
NY
NY
Thanks Jules, I'll try that tomorrow night
Re: How to mount Space Saver tire? [Re: 70440+6bbl] #553662
12/21/09 12:30 PM
12/21/09 12:30 PM
NY
NY
Jules- worked like a charm! I flat dropped them several times and using a soapy water mix, they seated and then I used air to do the rest
Re: How to mount Space Saver tire? [Re: 70440+6bbl] #553663
12/22/09 09:54 AM
12/22/09 09:54 AM
super gas
super gas
There you go!
Glad it worked out.
Jules
Re: How to mount Space Saver tire? [Re: JulesdaWiperman] #553664
10/30/11 01:16 PM
10/30/11 01:16 PM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
Snoopy,
Jules
I was thinking of having a space saver tire mounted to a rim that was black powder coated. Just wondering if that would still scratch up the rim?
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: How to mount Space Saver tire? [Re: TinCuda] #553665
10/30/11 01:20 PM
10/30/11 01:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Snoopy,
Jules
I was thinking of having a space saver tire mounted to a rim that was black power coated. Just wondering if that would still scratch up the rim?
Have you ever used an old Coates 40-40 type machine? With the nylon protector you have a slim chance of not doing damage but if the tire fights as much as I'd expect than you'll have scratches...
Re: How to mount Space Saver tire? [Re: 1_WILD_RT] #553666
10/30/11 01:45 PM
10/30/11 01:45 PM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
No, I have never mounted a tire without a split rim. I guess someone like Hibdon Tires would not be up to it? Sounds like they just need to get the tire on the rim, then drop it a couple of times. Like I said, I really have no idea.
