Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552628
12/13/09 05:58 PM
12/13/09 05:58 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
I think if you are planning on this type of racing over a period of time you can't afford not to run an aftermarket block.
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: 540dust] #552629
12/13/09 06:03 PM
12/13/09 06:03 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
im thinking hes an undercover salesman for indy
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: ro23car] #552630
12/13/09 06:19 PM
12/13/09 06:19 PM
IL
acme383 Offline OP
acme383  Offline OP
IL
nope! the reason i suggested Indy was just to limit HP. it could be Eldelbrock performer or Victor or B1/BS heads as well. just so there is no one head that out performs the others by a large margin. less than 400cfm.
"Beating the competition with a stick is just automatic!"
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552631
12/13/09 07:11 PM
12/13/09 07:11 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Dan, the big problem with a heads-up class like this is that there will be a few guys who will simply outspend and outrun the rest of the class, and everyone else will get tired of sucking hind teat and go home.
The idea of heads-up racing always sounds exciting, but when you try to keep it even with limits someone will always find a way around it, and you end up with a whole bunch of fighting.
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552632
12/13/09 07:27 PM
12/13/09 07:27 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... the reason i suggested Indy was just to limit HP. it could be Eldelbrock performer or Victor...
In that case, let's make it...
1)3700# min weight w/ driver (no weight breaks)
2)max cid 500 (must use a STOCK BLOCK!!!)
3)must run Edelbrock Performer RPM, Victor or MP "452", Stage VI/VII heads
4)single 4150 carb on cast available intake(no sheet metal)(no E85 or Methanol)
5)stock frame rails(no front or back halves)
6)no wheelie bars
7)max tire as stamped on tire 275/60R15 DOT legal or 28" x 9" slick
8)max 4 foward gears. manual or auto.
9)stock appearing interior. no sheet metal.
10)stock appearing bodies. no ground effects or spoilers.
11)hood scoops ok. max height 5"
Gee, I'm even giving up 48 cubes here, but the rest of it looks good to me.
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: BradH] #552633
12/13/09 07:32 PM
12/13/09 07:32 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Here are the rules.
1)3500# min weight(no weight breaks)
2)max cid 540(must use a STOCK BLOCK!!!)
3)must run INDY SR or 440-1 heads.
4)single carb on cast available intake(no sheet metal)(no E85 or Methanol)
6)no wheelie bars
7)max tire as stamped on tire. 31x10.5W
11)hood scoops ok. max height 10"
Sorry, but I have to ask... does your car fit these rules EXACTLY, by some chance?
LMAO
Im "actually" 540.7 ???
probably 3300-3400 ish
World Alum block
Custom dash (gauge area only"
Mopar Performance
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552634
12/13/09 07:37 PM
12/13/09 07:37 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
A small block would win it anyway. ..Phill
