A-body to e-body disc brake swap????? #552166
12/12/09 06:06 PM
12/12/09 06:06 PM
Odessa, Tejas
ChallengerRTSE Offline OP
Odessa, Tejas
What parts are needed off a 73/74 a-body disc brake to convert a 1970 e-body with drum brakes??
Re: A-body to e-body disc brake swap????? [Re: ChallengerRTSE] #552167
12/12/09 06:52 PM
12/12/09 06:52 PM
Everythin from the spindle outward: spindle/rotor/dust shield/hose/bearings etc. I believe you're good on the E body UCA/upper ball joint, not sure on the lower ball joint. Call your parts house & see if the app is the same #.
Re: A-body to e-body disc brake swap????? [Re: RapidRobert] #552168
12/12/09 07:48 PM
12/12/09 07:48 PM
BDW Offline
BDW  Offline
Re: A-body to e-body disc brake swap????? [Re: ChallengerRTSE] #552169
12/12/09 11:38 PM
12/12/09 11:38 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
73-up A- body disc brakes are the same spindles as were used on 73-74 E -bodies. The calipers on E-body cars were pin type instead of sliders. I used A-body spindles on my 71 Challenger, and just swapped to pin type caliper adapters. Then I bought calipers and hoses for a 71 Challenger. I used the proportioning valve off the A-body, and it works just fine. My car has power brakes, so I ordered a NEW master cylinder for a 73 Challenger. I made my own lines going to the proportioning valve. The car stops great. Good luck.
Re: A-body to e-body disc brake swap????? [Re: JDMopar] #552170
12/13/09 12:47 AM
12/13/09 12:47 AM
Are these single piston calipers?
