C-body engine swap.
#551744
12/12/09 02:52 PM
12/12/09 02:52 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
On a C-body engine swap from a /6 to a BB, there was an article somewhere many years ago that showed how to use some other model's motor mounts. Does anyone remember that article of what the article said? The first person that says "Check with Schumacher" gets a . They don't make a C-body /6 to BB adaptor...
Re: C-body engine swap.
[Re: Commando1]
#551751
12/13/09 06:27 PM
12/13/09 06:27 PM
Posts: 577 Grand Rapids, MI
11secondC
Grand Rapids, MI
Personally, I think www.moparfins.com/forum has more info.
You would seeing as how your a moderator there, with essentially past and present members of the Dock.
That being said, '65 to '73 would be the only years its a C body, and if you don't want to fab motor mounts, you can always swap the sub frame...
[Re: 11secondC]
#551753
12/13/09 08:14 PM
12/13/09 08:14 PM
Commando1
That being said, '65 to '73 would be the only years its a C body...
There were 74-78 C-bodies.
Fabbing the mounts would be easier than swapping out the whole subframe.
So, it goes back to my initial question, does anybody remember an old article that showed how to use existing mounts to drop in a BB in a C-body /6?
Geez just trying to help.
And I appreciated it. It just came out wrong.
[Re: 11secondC]
#551756
12/13/09 10:37 PM
12/13/09 10:37 PM
Posts: 37 Jorsey
Polaraco
Jorsey
Mopar made no real cars past '73
Other than having size incommon, the '65-'73 and the '74-'78 cars are two different animals all together...
Dana. . . We gonna start that again? LOL That falls under the catagory of the Imperial. Was it a C or wasn't it. (Let's not go there)
I thought Shoemacher made a mount to do that Stan. . .
[Re: Commando1]
#551758
12/14/09 08:49 AM
12/14/09 08:49 AM
Posts: 2,346 west palm beach, florida
modelmakerinc
just to chime in my I agree with 11secondC (Dana) the c-body changed completely after 73 and the Imperial was a "D" body Swaping the front subframe is much easier, once you remove all the sheetmetal you can install your engine, trans, headers, etc. and all accessories before the body parts go back on.
[Re: Commando1]
#551759
12/14/09 12:19 PM
12/14/09 12:19 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
What year C ?
65-68 and/or 69-73.
So as long as we're on Moparts trying to get solid info about cars that are used for engine donors, just consider... Nobody on this site has ever bothered to look at a /6 or LA C-body as there is nothing underhood that interests them.
I don't have your answer, but remember - the 65 C has a special motormount on the driverside.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#551760
12/14/09 01:03 PM
12/14/09 01:03 PM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
My buddy had a 65 Fury 1 with a slant that we were going to bb, but the mounts were welded in, and so was the subframe. He decided the only easy way to do it was with elephant ears(motor plates).
Jeff Adams
64 426 Polara
[Re: 11secondC]
#551763
12/14/09 08:05 PM
12/14/09 08:05 PM
Commando1
Hey Stan, ya know what they say...imitation is the sincerest form of flattery
Agreed! 100% I know we're severely getting off-topic here but since I originated the thread, I feel it's OK.
The way it works is this: I have an unbridled passion for "strippers". No, not the kind my wife won't allow me to have, but, the two door post sedans with zero options, lots of delete items, a four speed, and a huge mofo of an engine. It's a throwback to my developemenatal years of the early sixties when there were no "muscle cars". Savoy 413's, Biscayne 409's, Galaxie 406's... doesn't matter. If I see a /6 3 speed, regardless what it's in, my brain goes into triple overtime.
