Rear End offset Shackle and Perch Kits for B/E #551546
12/12/09 05:27 AM
12/12/09 05:27 AM
Millersville, PA
HemiChallenger Offline OP
Millersville, PA
Okay guys i have a question that i hope someone can give me answer for. I'm Trying to put a E-Body Dana into a 71+ B-Body. Is there anyone who makes the correct offset Shackle and Perch Kits?
Please let me know!
Thanks,
Steve
Re: Rear End offset Shackle and Perch Kits for B/E [Re: HemiChallenger] #551547
12/12/09 07:11 AM
12/12/09 07:11 AM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Check with DR. Diff here on the board. He should have what you need.
Re: Rear End offset Shackle and Perch Kits for B/E [Re: Classof70Chally] #551548
12/12/09 08:54 AM
12/12/09 08:54 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Dr Diff will definitely have the components...Hi Steve ! ...I did'nt move the springs when I did that swap...Just the rear perches...Still had plenty of room for a 10 inch rim... Here's a pic of an E-body rear in a B-body...This is a 10 inch rim with a Mickey Thompson 28x12 tire...
Re: Rear End offset Shackle and Perch Kits for B/E [Re: screamindriver] #551549
12/12/09 09:46 AM
12/12/09 09:46 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Why not just cut the perches off and reweld them in the right location?
Re: Rear End offset Shackle and Perch Kits for B/E [Re: scatpacktom] #551550
12/12/09 01:09 PM
12/12/09 01:09 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Well, for A, not everybody has a torch and a welder and B, you might want to put it back to stock someday.
Re: Rear End offset Shackle and Perch Kits for B/E [Re: Classof70Chally] #551551
12/14/09 04:01 AM
12/14/09 04:01 AM
Millersville, PA
Millersville, PA
I dont want to distort the original factory perches of an e body rear to have them fit a 71 b-body because the rear is a "loner" until it can go into my challenger in a few years. So just trying to see if there is any kit available or if im going to have to work with what i got.
Thanks,
Steve
Re: Rear End offset Shackle and Perch Kits for B/E [Re: HemiChallenger] #551552
12/14/09 05:30 AM
12/14/09 05:30 AM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
It is a very simple matter to remove the perches and fit new ones in the right location.
Chances are the factory never put them in exactly the right location anyway.
By fitting new perches you can get the axle centered under the car (something Chrysler was not very good at) and also make any pinion angle adjustments needed.
2002 Chevrolet Corvette 5.7 LS1 2011 Alpha Romeo Giulietta Veloce 1.6 JTD Because running a Mopar in the UK is getting TOO expensive!!
Re: Rear End offset Shackle and Perch Kits for B/E [Re: Roppa440] #551553
01/28/10 02:20 PM
01/28/10 02:20 PM
Millersville, PA
Millersville, PA
Thanks for the tips. When removing the perches and putting new ones on should this be done by a shop, or can i do this? I'd really hate to have to pay someone else but if its need i will.
Anyone have any tips for doing this?
Re: Rear End offset Shackle and Perch Kits for B/E [Re: HemiChallenger] #551554
01/29/10 06:20 AM
01/29/10 06:20 AM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
Cut the old perches off.
Fit the axle with the new perches in place. But just bolted together. The U-bolts will hold the axle in place.
Center the axle under the car. Check the axle end play is adjusted correctly first.
Once centered check your pinion angles. Get the angle the same at the rear UJ as it is at the trans end. You need sommething more that 1.5 degrees and less than 3 degrees (see drawing). Then drop the pinion slightly from that setting. How much you drop it is subject to debate as it depends on how much your pinion rises under load.
Once you have everything lined up just tack weld the perches in place so they stay put.
Now if you can weld OK you can just weld the perches on right there. If you would rather have someone do it for you might have to remove the axle and get it done somewhere.
Re: Rear End offset Shackle and Perch Kits for B/E [Re: Roppa440] #551555
01/29/10 11:38 AM
01/29/10 11:38 AM
Millersville, PA
Millersville, PA
Wow thanks for that response! Your description and diagram will be very helpful
Re: Rear End offset Shackle and Perch Kits for B/E [Re: HemiChallenger] #551556
01/30/10 08:23 AM
01/30/10 08:23 AM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
Just make sure you understand that the UJ angles are the angle of the driveshaft in relation to the angle of the trans and the pinion.
These are not the same as the angles in relation to gravity or the ground.
You can use the oil pan to get the angle of the trans and the end of the pinion or the area the pinion snubber mounts to for the angle at that end in relation to the driveshaft.
