exhaust manifold bolts #550643
12/10/09 11:10 PM
12/10/09 11:10 PM
Cumberland County, NJ
coronetkid Offline OP
so i have to get the exhaust manifolds off of my 318. they are leaking pretty bad and driving me nuts.problem is i checked them out and half of the bolt heads are already rounded off and really rusty. so i need suggestions on removing them and trying not to break them off in the head. the engine is my w100 and i have just hand tools. thanks
Re: exhaust manifold bolts [Re: coronetkid] #550644
12/10/09 11:17 PM
12/10/09 11:17 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
I would suggest warming-it-up and getting some 6 point sockets.
Re: exhaust manifold bolts [Re: coronetkid] #550645
12/10/09 11:18 PM
12/10/09 11:18 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Try tapping a smaller metric socket on with a hammer.
Re: exhaust manifold bolts [Re: dOc …] #550646
12/10/09 11:20 PM
12/10/09 11:20 PM
warming it up as in use a torch?
Re: exhaust manifold bolts [Re: mercman1] #550647
12/10/09 11:20 PM
12/10/09 11:20 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
and soak them a few times with a good penetrant and let them sit for a while...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: exhaust manifold bolts [Re: wingman] #550648
12/11/09 09:16 AM
12/11/09 09:16 AM
scratchnfotraction Offline
sb are not to bad,got to watch the end studs
the smaller socket tapped on is one good way,I have done that most times with them comeing out
yes a torch and red hot they come out easy,I just run a couple beads withthe wire feed welder to get a BB stud red hot..it came right out
if you had to,you could torch the head off to remove the manny,then it would leave a good part of the bolt sticking out to grab with vise grips
start spraying a couple days head of time with PB-blaster and run the engine some to wick it in good,that helps with rust for sure
the 2 end studs are in water,so be ready for it to drain if they come out
I use the copper rtv on the mannys and head with no gasket on sb,never have a leak with them,let cure over night and no more leaks
buff them down with a scotch pad and grinder wheel to clean them up nice and stick them
IMO,I would undo the head pipe first then remove the manny,spray those bolts down good with blaster as well
good luck and hope none break
Re: exhaust manifold bolts [Re: scratchnfotraction] #550649
12/11/09 11:08 AM
12/11/09 11:08 AM
Az
Crizila Offline
Crizila  Offline
Az
I've also had some luck using a punch and wacking them straight on a few times - after you soak them with PB Blaster.
Fastest 300
Re: exhaust manifold bolts [Re: Crizila] #550650
12/11/09 11:34 AM
12/11/09 11:34 AM
thanks guys i'll start soaking them today and try to pull them sunday
Re: exhaust manifold bolts [Re: coronetkid] #550651
12/11/09 12:01 PM
12/11/09 12:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you can find a dealer get some Zep45.It makes PB Blaster look like water.We used PB at work along with Castle thrust.Thrust was good PB was almost as good as using nothing.Zep was the best stuff Ive used in 25 years as a pro.Rocky
Chrysler Firepower
Re: exhaust manifold bolts [Re: therocks] #550652
12/11/09 10:02 PM
12/11/09 10:02 PM
do regular parts stores carry replacement man bolts? anyone know the correct size for a 318 off hand?
Re: exhaust manifold bolts [Re: coronetkid] #550653
12/12/09 09:48 AM
12/12/09 09:48 AM
last i got was from napa in the dorman fastner line
I got 2-5 gallon buckets of nothing but sb bolts from yrs of working on them and junking a few
most come from going to headers
I can scratch you up some "used" ones if you need some ginnys
any grade 5 or 8 bolt from the hardware should work also
Re: exhaust manifold bolts [Re: coronetkid] #550654
12/12/09 09:49 AM
12/12/09 09:49 AM
5/16 maybe
Re: exhaust manifold bolts [Re: scratchnfotraction] #550655
12/12/09 12:50 PM
12/12/09 12:50 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Exhaust bolts are a pain!!! I'd definitely use new bolts and anti-seize at the minimum. Will make them easier to remove next time.
I can't recall for sure, but it seems like stainless steel bolts will not seize in cast iron. Or is it stainless steel studs with brass nuts? Maybe someone can clarify this point.
Re: exhaust manifold bolts [Re: QuickDodge] #550656
12/12/09 04:00 PM
12/12/09 04:00 PM
Atlanta GA
spank04 Offline
super gas
spank04  Offline
super gas
Atlanta GA
go to sears and get those sockets for rounded heads,comes in a kit
Re: exhaust manifold bolts [Re: spank04] #550657
12/15/09 07:29 PM
12/15/09 07:29 PM
got them all out today with no breakage no more leaky manifold
Re: exhaust manifold bolts [Re: coronetkid] #550658
12/16/09 09:15 AM
12/16/09 09:15 AM
I knew you could do it
good job
