Racer Brown Cams #550396
12/10/09 04:53 PM
12/10/09 04:53 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
What is the general consensus on RB cams. I have read a lot of people swear by them and others say they are old technology and more modern cams profiles are better.
There is a book on big block mopars where the author says to look for a hydraulic cam with duration @.050 that is 85% of advertised. On a solid look for 90%. This is supposed to indicate an aggressive ramp/lobe profile. I have looked at an RB ssh-25 cam with [Email]238@.050[/Email] and 285 adverstised. Its 83.5% does this mean its not ground to take advantage of the .904 lifter? Most to the hyd cams I have looked at including the Comp and Lunati cams that are supposed to be ground for the mopar lifter do not come out to be 85% or more either.
I guess I should just take the cam grinders word for it. Who to trust? What are peoples thoughts about Jim from RB?
Steve
Re: Racer Brown Cams [Re: srunge55] #550397
12/10/09 05:11 PM
12/10/09 05:11 PM
P
Paul_Fancsali Offline
P
Well I can say that I love the Racer Brown cam I run in my 340 car goes like a bat out of hell! Idles great with good vacuum and will pull to 6500. and too top it off gets close to 14MPG with 4.10s and 25" tires to boot. A clown in a newer vette found out the hard way recently that a 340 is no punk from a dead stop.
Re: Racer Brown Cams [Re: srunge55] #550398
12/10/09 05:48 PM
12/10/09 05:48 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Check it for core shift after it's installed in the block, with the gear on and the lifters in. That's probably good advice with any cam.
Re: Racer Brown Cams [Re: srunge55] #550399
12/10/09 08:58 PM
12/10/09 08:58 PM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
I am very happy with mine also, it is in a 340 dart, very mild grind, with less advertised duration than the stock cam but it will run 13.7 at 102mph with 3.23 gears and stock exhaust, plus I can get about 18+ mpg on the highway. I will go with them again on my next motor.
Re: Racer Brown Cams [Re: dd340] #550400
12/10/09 09:39 PM
12/10/09 09:39 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I'm happy with mine, Jim is very easy to talk with.
Re: Racer Brown Cams [Re: dd340] #550401
12/10/09 09:40 PM
12/10/09 09:40 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I ran the SSH-38 for while then stepped up to the SSH-44. Call Jim and talk to him about your combination. He's no stranger to Mopars.
Re: Racer Brown Cams [Re: bobby66] #550402
12/11/09 12:51 AM
12/11/09 12:51 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Jim was very helpful and informative for me on a solid cam
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Racer Brown Cams [Re: srunge55] #550403
12/11/09 07:29 AM
12/11/09 07:29 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
The one that he ground for my stroker is awesome.
This is the land of the free because of the brave
Re: Racer Brown Cams [Re: rbstroker] #550404
12/11/09 07:45 AM
12/11/09 07:45 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Small blocks like this cam either in the regular version 340-360 or the stroker version 408-416
Racer Brown SSH 25/44 286/292 238/242@50 .485/.510 lift 108cl
