Magnum Rockers #550147
12/10/09 08:49 AM
12/10/09 08:49 AM
Minnesota
snojet Offline OP
snojet  Offline OP
Minnesota
Has anybody installed small block chevy rockers on magnum heads? Is it straight forward or is it a pain. Thank you
Re: Magnum Rockers [Re: snojet] #550148
12/10/09 11:49 AM
12/10/09 11:49 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
it is not a straight bolt on..
there kits from hughes and comp cams that allow the use of sbc rockers.
i believe the problem is that the magnum heads uses 5/16 studs and the smallest sbc rocker is 3/8 studs.
hughes sell studs with 5/16 treads that go into head, but with 3/8 stud for rockers.
http://www.hughesengines.com/Index/produ...2Nlc3Nvcmllcw==
Tony
70 AARCuda Vitamin C
Re: Magnum Rockers [Re: snojet] #550149
12/10/09 03:01 PM
12/10/09 03:01 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
I have the Hughes kit with PEP roller rockers on my magnum Iron Rams, the worst part about them is getting the roller tip centered over the valve by using the guide plates. Other than that they seem to work fine. Actually thinking of swapping to their new Shaft mounted magnum rockers which weren't available when I went with the ones I have.
Re: Magnum Rockers [Re: Mopar73340] #550150
12/10/09 04:29 PM
12/10/09 04:29 PM
Minnesota
snojet Offline OP
snojet  Offline OP
Minnesota
What do you like about the shaft type rockers?
Re: Magnum Rockers [Re: Mopar73340] #550151
12/10/09 04:35 PM
12/10/09 04:35 PM
Az
Crizila Offline
Crizila  Offline
Az
I've had mine for several years now with no problems running a fairly large hydraulic ( over .600" lift ). They are a pain to adjust though ( getting the roller tips centered on the valve stems ). I'd go with the new shaft set up too, but it's a little pricey at this time.
Fastest 300
Re: Magnum Rockers [Re: snojet] #550152
12/10/09 05:45 PM
12/10/09 05:45 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
They are more of a conventional Chrysler setup and the problem with centering the roller over the valve stem should be eliminated. The current setup has about 1000 miles and 6 dyno runs on them and so far so good.
