Aftermarket cam and stock valve train
#549886
12/09/09 08:46 PM
12/09/09 08:46 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Looking for a good low priced cam for my 72SSP budget beater. I have a 1975 440 truck motor for it. What is a good cam that I can use with the stock valve train? Will be an auto with 391 gears and stock converter. Was thinking of something with around a 480 lift.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: Aftermarket cam and stock valve train
[Re: forphorty]
#549888
12/09/09 11:08 PM
12/09/09 11:08 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
low comp smog motor, I'd use a comp XE268 or voodoo 60302 or 60303.
[Re: MoparforLife]
#549890
12/09/09 11:33 PM
12/09/09 11:33 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Stock springs? voodoo 60301 TOPS... Beware, it's a slippery slope! Valve spings--->valve seals--->valve job and all of sudden your $400 into a cam swap on top of the cam lifters and timing chain. if you go poking around in your engine bring cash!
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#549891
12/09/09 11:49 PM
12/09/09 11:49 PM
moparmarks
I saved the truck from the crusher thinking that this motor had 63,000 original miles. After getting into it, looks like it may have been rebuilt. New timing chain, freeze plugs, 010 on crank, ect,ect. Very clean inside. Did I mention low budget beater?lol Just want to perk it up abit.
[Re: DaytonaTurbo]
#549894
12/10/09 08:59 AM
12/10/09 08:59 AM
patrick
Grand Haven, MI
I'd at the very least replace the springs with comp 916's.
[Re: patrick]
#549895
12/12/09 11:28 AM
12/12/09 11:28 AM
moparmarks
I like those Voodoo cams. I also like that they are 3 bolt except this motor looks to have a new 1 bolt timing set. Man, Jeggs charges 60.00 more than Summitt for these. If valve bind or float maybe a problem then I might just leave the stock one in. Maybe put in the 454/454 Comp cam that I have. I think the Summitt cams have to much duration for the lift that they have for my setup. The focus is low budget here. Have 40.00 in this new Comp cam and lifters.
