lucas oil treatment? any one else #548277
12/07/09 04:27 PM
12/07/09 04:27 PM
Michigan, US
ben1692 Offline OP
ben1692  Offline OP
Michigan, US
i started running 1 quart of lucas oil treatment to 8 quarts of oil every oil change starting this year. pulled the motor this winter and the bearings looked like brand new. has anyone else use this product and did it work as well for them or not so good?
Re: lucas oil treatment? any one else [Re: ben1692] #548278
12/07/09 04:33 PM
12/07/09 04:33 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Nope,
We ran that stuff in our late model small block, 8000+ rpm and we found oil psi spikes, drops, very uneven stuff. Our pan holds a LOT of oil, 10 qt with a kick out in it, we found that stuff foammed up terribly, we ran VR1 race oil with 2 qts of lucas. They told up the ratio we were using. Well we tried to just run brad penn, no more issues...
Kasey
Re: lucas oil treatment? any one else [Re: Moparnut426] #548279
12/07/09 06:26 PM
12/07/09 06:26 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
That sounds exactly like what BobIsTheoilGuy.com had found during his testing...
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Re: lucas oil treatment? any one else [Re: ben1692] #548280
12/07/09 06:34 PM
12/07/09 06:34 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I use half qt with six qts oil works great
Re: lucas oil treatment? any one else [Re: BigBlockMopar] #548281
12/07/09 06:35 PM
12/07/09 06:35 PM
Moparnut426 Offline
Moparnut426  Offline
Yep I wouldnt use it in my lawn mower, but id use it in a capacino machine
Re: lucas oil treatment? any one else [Re: Moparnut426] #548282
12/07/09 06:46 PM
12/07/09 06:46 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use it as a final pour on lube for the cam and lifters after the engine is assembled,especuially if it is not going to be fired soon.
Re: lucas oil treatment? any one else [Re: B G Racing] #548283
12/07/09 06:50 PM
12/07/09 06:50 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
Junk!!! All you need is good oil.
Re: lucas oil treatment? any one else [Re: hemi471] #548284
12/07/09 06:56 PM
12/07/09 06:56 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I use a qt with 7 qts of rotella 15-40. Have for years...last time motor was out ...600 runs bearing look new.. But there seems to be a lack of prove of whats in it... Bob test don't fly with me...two gears in a box is not whats happing in my motor.. I think maybe it is what you mix it with with also..
Re: lucas oil treatment? any one else [Re: ben1692] #548285
12/07/09 06:58 PM
12/07/09 06:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I used their power steering fix it stuff... worked great
in my street car
Re: lucas oil treatment? any one else [Re: B G Racing] #548286
12/07/09 07:12 PM
12/07/09 07:12 PM
with BG, lucas oil tratment is sticky and has to lubricate and coat everything, did u ever feel that stuff on your fingers.
Re: lucas oil treatment? any one else [Re: Moparnut426] #548287
12/07/09 07:30 PM
12/07/09 07:30 PM
Michigan, US
ben1692 Offline OP
ben1692  Offline OP
Michigan, US
i started using it because my cousins cantrell bros (top alcohol dragster) swear by it. they use a quart every pass including fresh oil. most all the guys in his class use it they go alot faster than i do. didnt see any foaming when i helped crew with them. they turn many more rpms than 8000
Re: lucas oil treatment? any one else [Re: ben1692] #548288
12/07/09 07:48 PM
12/07/09 07:48 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
I use it in everything .I give it credit for saving my motor when a junk crane gold rocker broke and the motor spit a lifter out of the bore and I lost all oil pressure. No harm to anything.Makes it a pain to set the lash because you can not hang onto anything its so slippery.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: lucas oil treatment? any one else [Re: MR_P_BODY] #548289
12/07/09 07:52 PM
12/07/09 07:52 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
in my street car
i'm with you on that mr.p. that stuff is great!
Re: lucas oil treatment? any one else #548290
12/07/09 09:17 PM
12/07/09 09:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
It is very sticky and it clings to the cam and lifters for a long time much like STP.We pour a generious amount on the cam and lifters and around the lifter bores as well as the tips of the rockers and pushrods,Some of our engines sit for months and some are shipped abroad.
Re: lucas oil treatment? any one else [Re: B G Racing] #548291
12/07/09 10:48 PM
12/07/09 10:48 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Re: lucas oil treatment? any one else [Re: B G Racing] #548292
12/07/09 11:04 PM
12/07/09 11:04 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I do the same thing in the valvetrain even after soaking lifters in a large coffee bucket.Coat the rocker shafts,tips,cam,,but BG,I have a question fer ya???????What "broad" are ya shippin to??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: lucas oil treatment? any one else [Re: hemi-itis] #548293
12/07/09 11:28 PM
12/07/09 11:28 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Lucas has a dislpay in the store that has 2 compartments, each with a series of plastic gears run by a hand crank. One compartment has straight motor oil, the other has Lucas fortified oil. When you crank the lucas setup, the oil clings to the gears and climbs up to the top gear much more readily than the straight oil set up.
I figure I don't need oil clinging to the crankshaft and other parts, I need it to easily shed from the rotating assembly and get back into the pan. So I don't use Lucas oil treatment in my race moter.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: lucas oil treatment? any one else [Re: Hemi_Joel] #548294
12/07/09 11:50 PM
12/07/09 11:50 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
I ran a little in my Getrag 5 speed behind my Cummins. I changed the oil, added the Lucas Oil treatment, to the specified oil for the trans. After that the trans shifted horribly, and was far more noisy. I ran it a while like that and it did not get better. I drained out the oil and as much Lucas as I could get out of it. I then refilled it with specified oil and ran the trans went back to shifting nice, and no more noise. Ran it a long time with lots of heavy loads, lots of tire chirping, speed shifts and such before the output shaft bearing finally became pitted and noisy.
I've since rebuilt it with new bearings, and filled it with synthetic oil, and had great service.
No Lucas for me.....
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: lucas oil treatment? any one else [Re: Hemi_Joel] #548295
12/08/09 08:44 AM
12/08/09 08:44 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
that was my feeling too. You want oil to lubricate using a thin boundary layer of oil- not a think heavy coating that will add weight and slow rotating components. you want the thiunnest oil possible that will still lubricate at the worst extreme that you run
Re: lucas oil treatment? any one else [Re: slippery440] #548296
12/08/09 11:26 AM
12/08/09 11:26 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
We used it at the shop.Some cars we used it in were pretty bad and customer wanted to get a little more time or eliminate soem noise.It worked in quite a few of them.Use it in my cars also.Never any problems.Rocky
Chrysler Firepower
