Re: lucas oil treatment? any one else
[Re: ben1692]
#548278
12/07/09 04:33 PM
12/07/09 04:33 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Nope,
We ran that stuff in our late model small block, 8000+ rpm and we found oil psi spikes, drops, very uneven stuff. Our pan holds a LOT of oil, 10 qt with a kick out in it, we found that stuff foammed up terribly, we ran VR1 race oil with 2 qts of lucas. They told up the ratio we were using. Well we tried to just run brad penn, no more issues...
Kasey
[Re: B G Racing]
#548286
12/07/09 07:12 PM
12/07/09 07:12 PM
We use it as a final pour on lube for the cam and lifters after the engine is assembled,especuially if it is not going to be fired soon.
with BG, lucas oil tratment is sticky and has to lubricate and coat everything, did u ever feel that stuff on your fingers. ![](/ubbthreads/images/graemlins/eeek.gif)
#548290
12/07/09 09:17 PM
12/07/09 09:17 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
It is very sticky and it clings to the cam and lifters for a long time much like STP.We pour a generious amount on the cam and lifters and around the lifter bores as well as the tips of the rockers and pushrods,Some of our engines sit for months and some are shipped abroad. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: B G Racing]
#548292
12/07/09 11:04 PM
12/07/09 11:04 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I do the same thing in the valvetrain even after soaking lifters in a large coffee bucket.Coat the rocker shafts,tips,cam,,but BG,I have a question fer ya???????What "broad" are ya shippin to?? ![](/ubbthreads/images/graemlins/smoke.gif)
[Re: hemi-itis]
#548293
12/07/09 11:28 PM
12/07/09 11:28 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Lucas has a dislpay in the store that has 2 compartments, each with a series of plastic gears run by a hand crank. One compartment has straight motor oil, the other has Lucas fortified oil. When you crank the lucas setup, the oil clings to the gears and climbs up to the top gear much more readily than the straight oil set up. I figure I don't need oil clinging to the crankshaft and other parts, I need it to easily shed from the rotating assembly and get back into the pan. So I don't use Lucas oil treatment in my race moter. ![](/ubbthreads/images/graemlins/Twocents.gif)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#548294
12/07/09 11:50 PM
12/07/09 11:50 PM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
I ran a little in my Getrag 5 speed behind my Cummins. I changed the oil, added the Lucas Oil treatment, to the specified oil for the trans. After that the trans shifted horribly, and was far more noisy. I ran it a while like that and it did not get better. I drained out the oil and as much Lucas as I could get out of it. I then refilled it with specified oil and ran the trans went back to shifting nice, and no more noise. Ran it a long time with lots of heavy loads, lots of tire chirping, speed shifts and such before the output shaft bearing finally became pitted and noisy.
I've since rebuilt it with new bearings, and filled it with synthetic oil, and had great service.
No Lucas for me.....
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: Hemi_Joel]
#548295
12/08/09 08:44 AM
12/08/09 08:44 AM
Posts: 15,493 the boonies
aarcuda
the boonies
that was my feeling too. You want oil to lubricate using a thin boundary layer of oil- not a think heavy coating that will add weight and slow rotating components. you want the thiunnest oil possible that will still lubricate at the worst extreme that you run
[Re: slippery440]
#548296
12/08/09 11:26 AM
12/08/09 11:26 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
We used it at the shop.Some cars we used it in were pretty bad and customer wanted to get a little more time or eliminate soem noise.It worked in quite a few of them.Use it in my cars also.Never any problems.Rocky
Chrysler Firepower
