Re: Your opinions Please- my motor is finally apart ! *DELETED* [Re: 493_DART] #547809
12/23/09 05:58 AM
12/23/09 05:58 AM
Texas
6packattk Offline
6packattk  Offline
Texas
Post deleted by 6packattk
Re: Your opinions Please- my motor is finally apart ! [Re: 6packattk] #547810
12/23/09 06:14 AM
12/23/09 06:14 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
6pak--
this thread is pretty FAR from going south actually....
i was just looking for some good Moparts Race eyeballs on some pics of my stuff
Just have to warm up to Quicktree is all......
Re: Your opinions Please- my motor is finally apart ! [Re: 6packattk] #547811
12/23/09 06:20 AM
12/23/09 06:20 AM
gregsdart Offline
gregsdart  Offline
I agree on the roller, great time to go there. Deducting the cost of the new solid cam and lifters lowers the cost per hp quite a bit.
Re: Your opinions Please- my motor is finally apart ! [Re: gregsdart] #547812
12/23/09 06:29 AM
12/23/09 06:29 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
id love to roller . We shall see what happens with $$$ the next few months .
let me throw this out there-- i have new Isky 8005 springs. Will they be ok with a .600 ,or close, roller..... ?
Re: Your opinions Please- my motor is finally apart ! #547813
12/23/09 06:29 AM
12/23/09 06:29 AM
sweden
sshemi Offline
sshemi  Offline
sweden
only 182 passes and you need a freshen up who can afford that? we have almost put that many just testing nad getting things sorted out.
175 were just to set the pinion angle
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547814
12/23/09 08:08 AM
12/23/09 08:08 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Thats cool
post your combo Quicktree , maybe i can learn something from you.
"half the motor" would be...what.....a 383 or smaller with a 509 cam or smaller / pump gas / n/a , around 9:1 max ?
is that about right ? cuz i dont have a lot in this motor....
I hope you know I am poking fun at you some of you guys take things way to serious. my motor is 365ci 11.5:1 CR with a 575 comp cam.
Re: Your opinions Please- my motor is finally apart ! [Re: sshemi] #547815
12/23/09 08:09 AM
12/23/09 08:09 AM
Q
Quicktree Offline
Quicktree  Offline
Q
baa it was set before the first pass
Re: Your opinions Please- my motor is finally apart ! [Re: Quicktree] #547816
12/23/09 08:35 AM
12/23/09 08:35 AM
Lehigh Acres, Florida
rickstershemi Offline
But did you phase it correctly
Rickster
Re: Your opinions Please- my motor is finally apart ! [Re: rickstershemi] #547817
12/23/09 09:13 AM
12/23/09 09:13 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
I agree with replacing the cam. With the lower zinc and phosphorus in today's oils flat tappet cams do wear quickly.
Also, I would chamfer the oil passages in the crank to improve oil flow and eliminate stress risers.
Re: Your opinions Please- my motor is finally apart ! [Re: rickstershemi] #547818
12/23/09 09:52 AM
12/23/09 09:52 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Rickster
quit messing up the guys post
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547819
12/23/09 11:26 AM
12/23/09 11:26 AM
gregsdart Offline
gregsdart  Offline
On a used street roller, maybe. Solid race roller, not a chance.
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547820
12/23/09 03:45 PM
12/23/09 03:45 PM
NC
440Jim Offline
440Jim  Offline
NC
Those are for a flat tappet cam, don't waste your time running them with a roller cam. The spec is about 135 seat (1.875), 395 open (.650 lift).
