bb milodon oil pump #546287
12/05/09 07:55 PM
12/05/09 07:55 PM
ky
68roadrunner Offline OP
ky
who likes this pump, and who dont and why? thanks lee
Re: bb milodon oil pump [Re: 68roadrunner] #546288
12/05/09 08:38 PM
12/05/09 08:38 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I've been using them for 15 years. Never had a failure. I have run 8500 RPM with the dual line pump, but don't really like the kit that converts a stock pump.
Re: bb milodon oil pump [Re: 68roadrunner] #546289
12/05/09 08:39 PM
12/05/09 08:39 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Milodon Sucks Big Donkey Dongs, but that's just my opinion.
Re: bb milodon oil pump [Re: RussW] #546290
12/05/09 09:16 PM
12/05/09 09:16 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have it no problems at all?? The biggest plus is for the do-it-your-self-ers, they can buy everything they need from them so they are covered.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: bb milodon oil pump [Re: bigtimeauto] #546291
12/05/09 09:30 PM
12/05/09 09:30 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have been using the system for over 25 years.The pump never failed on it's own,was always due to debris that was passed through the rotors.Now,as per Jimi Vignogna's reccomendation I use 2 "PREFILTERS" that are in the oil lines between the pan & pump.I also run a duel oil filter setup with Moroso oil filters that have NO BYPASS.My system can filtrate 36 gph and in the event of a mechanical failure,absolutley NO debris gets pumped past the filters.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: bb milodon oil pump [Re: hemi-itis] #546292
12/05/09 10:19 PM
12/05/09 10:19 PM
sg66mopar Offline
sg66mopar  Offline
Yeah there's probably better pumps out there. I think I can buy about 3 or 4 Milodon's for the same cost. The one I have on the motor now works good. Not much else needs to be said.
Might have to look at the pre filter idea. Brand new Milodon this year and already chewed up the rotor and impeller from hard as a rock debris going through it.
Re: bb milodon oil pump [Re: 68roadrunner] #546293
12/05/09 10:51 PM
12/05/09 10:51 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
My motor has been together 10 years on one. I have the 1.100" rotors. It's the complete dual line Milodon set up with their aluminum pump.
I'd say at the present time my next step could only be a dry sump system.
"disclaimer"; quality hose, fittings and connections to keep it from sucking any air or leaking oil.
Always pay attention to the little details
Re: bb milodon oil pump [Re: roadhazard] #546294
12/06/09 12:19 AM
12/06/09 12:19 AM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
How about a source for these prefilters! I just snapped a shaft from a a piece of debris.
Anyone ever use a check valve on the suction lines??
RIP
Re: bb milodon oil pump [Re: sc4400] #546295
12/06/09 01:40 AM
12/06/09 01:40 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Run a Melling HV pump add the pump cover and go with a swinging pickup...The stock style HV pump will feed 99.9% of most engines on this board in this fashion..
I have personally turned a 560 CID big block 8K no problems...
Chuck at Best Machine said they will feed to 10K.
No green gasket to blow. I run aftermarket blocks, and I plum one line from the oil port by the timing chain cover on these Indy Maxx blocks, and the World blocks...For duel line setups, this would be one, and from the pump cover bac to the pickup is the other.
Re: bb milodon oil pump [Re: sc4400] #546296
12/06/09 02:46 PM
12/06/09 02:46 PM
hemi-itis Offline
hemi-itis  Offline
RIP
http://www.summitracing.com/search/?keyword=inline%20oil%20filter&dds=1,,,,,,This will help
Re: bb milodon oil pump [Re: hemi-itis] #546297
12/06/09 04:54 PM
12/06/09 04:54 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Hemi-itis, never thought about pre-filtering the pump
I have a 35+ year old Milodon pump that still works and a new one for my Hemi. I also got bulkheads for the swinging pickup for prevention against leaks and also obtained one of Ted's billet oil pump covers.
Re: bb milodon oil pump [Re: Defbob] #546298
12/06/09 05:27 PM
12/06/09 05:27 PM
hemi-itis Offline
hemi-itis  Offline
Defbob,don,t forget to use oil filters with no bypass.When 19 gpm hits an oil filter that flows 12gpm,the bypass opens and you ain't filtering s#$%!!I use 2 Moroso oil filters that flow 16 each and handle 8000 rpm,NO PROBLEM
Re: bb milodon oil pump [Re: Defbob] #546299
12/06/09 05:39 PM
12/06/09 05:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most if not all guys that run dry sumps use pre
filters... I know I do... dont want to tear up a
big dollar pump... you can see them coming across
the pan area in my pic
Re: bb milodon oil pump [Re: RussW] #546300
12/06/09 05:47 PM
12/06/09 05:47 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
and what source of pumpage do you use in the rocke ship your steering? dam i kinda sound like cw
Re: bb milodon oil pump [Re: RussW] #546301
12/06/09 05:48 PM
12/06/09 05:48 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
and what source of pumpage do you use in the rocket ship your steering? dam i kinda sound like cw
Re: bb milodon oil pump [Re: ro23car] #546302
12/06/09 06:18 PM
12/06/09 06:18 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
you're getting shorter by the minute
Re: bb milodon oil pump [Re: Defbob] #546303
12/06/09 06:24 PM
12/06/09 06:24 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
lol maybe its the meds lol. gotta talk to the doc.
Re: bb milodon oil pump [Re: hemi-itis] #546304
12/06/09 06:26 PM
12/06/09 06:26 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
what filters are you using? Both Moroso #22470 and K&N #HP-3001 (I currently use) have filter bypass relief valves
Re: bb milodon oil pump [Re: hemi-itis] #546305
12/06/09 06:30 PM
12/06/09 06:30 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
first let me say i'm not trying to start a peeing contest and i myself wouldn't want oil bypassing the filter. that said regardless of how much the pump flows it is the amount flowing through the engine that has to go through the filter. any more than that only gets pumped in circles from the pump discharge through the relief valve then back into the suction. imho there are very few engines that are going to flow what the pump does. i know Andy Finkbeiner did research on different pumps and he may have some accurate info as far as how much oil these engines are actually using. imho as mentioned using screens on the pump suction is a good.
Re: bb milodon oil pump [Re: jamesc] #546306
12/06/09 08:13 PM
12/06/09 08:13 PM
hemi-itis Offline
hemi-itis  Offline
Jim,I was using a single Fram HP filter when I had a lifter failure.As the grindings washed to the pan,it was sent right out the pump,through the filter and contaminated all bearings and imbedded some in the piston skirts.After changing to duel filters and a prefilter and did have another lifter failure.This time EVERYTHING was caught in the filters with no oil system contamination.The Milodon pump ia advertised to pump 19 to 21 gallons per minute.The Moroso filter is advertised to flow 16 gpm,,,sooooooo,,I use a double oil filter set up.Some very expensive R&D out of my pocket and I can only hope to save a member of my MOPARTS family a few from my findings
