Re: bb milodon oil pump
[Re: RussW]
#546290
12/05/09 09:16 PM
12/05/09 09:16 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I have it no problems at all?? The biggest plus is for the do-it-your-self-ers, they can buy everything they need from them so they are covered.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: 68roadrunner]
#546293
12/05/09 10:51 PM
12/05/09 10:51 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
My motor has been together 10 years on one. I have the 1.100" rotors. It's the complete dual line Milodon set up with their aluminum pump. I'd say at the present time my next step could only be a dry sump system. "disclaimer"; quality hose, fittings and connections to keep it from sucking any air or leaking oil. Always pay attention to the little details
[Re: roadhazard]
#546294
12/06/09 12:19 AM
12/06/09 12:19 AM
Posts: 447 lake charles, la
sc4400
lake charles, la
How about a source for these prefilters! I just snapped a shaft from a a piece of debris. Anyone ever use a check valve on the suction lines?? RIP
[Re: sc4400]
#546296
12/06/09 02:46 PM
12/06/09 02:46 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
RIP
http://www.summitracing.com/search/?keyword=inline%20oil%20filter&dds=1,,,,,,This will help
[Re: Defbob]
#546298
12/06/09 05:27 PM
12/06/09 05:27 PM
hemi-itis
Defbob,don,t forget to use oil filters with no bypass.When 19 gpm hits an oil filter that flows 12gpm,the bypass opens and you ain't filtering s#$%!!I use 2 Moroso oil filters that flow 16 each and handle 8000 rpm,NO PROBLEM
[Re: Defbob]
#546299
12/06/09 05:39 PM
12/06/09 05:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hemi-itis, never thought about pre-filtering the pump
I have a 35+ year old Milodon pump that still works and a new one for my Hemi. I also got bulkheads for the swinging pickup for prevention against leaks and also obtained one of Ted's billet oil pump covers.
Most if not all guys that run dry sumps use pre filters... I know I do... dont want to tear up a big dollar pump... you can see them coming across the pan area in my pic
[Re: RussW]
#546300
12/06/09 05:47 PM
12/06/09 05:47 PM
Posts: 1,162 s e mich
ro23car
s e mich
Milodon Sucks Big Donkey Dongs, but that's just my opinion.
and what source of pumpage do you use in the rocke ship your steering? dam i kinda sound like cw
[Re: RussW]
#546301
12/06/09 05:48 PM
12/06/09 05:48 PM
ro23car
s e mich
and what source of pumpage do you use in the rocket ship your steering? dam i kinda sound like cw
[Re: ro23car]
#546302
12/06/09 06:18 PM
12/06/09 06:18 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
you're getting shorter by the minute
[Re: Defbob]
#546303
12/06/09 06:24 PM
12/06/09 06:24 PM
ro23car
s e mich
lol maybe its the meds lol. gotta talk to the doc.
[Re: hemi-itis]
#546305
12/06/09 06:30 PM
12/06/09 06:30 PM
Posts: 5,875 communist bloc of new jersey
jamesc
first let me say i'm not trying to start a peeing contest and i myself wouldn't want oil bypassing the filter. that said regardless of how much the pump flows it is the amount flowing through the engine that has to go through the filter. any more than that only gets pumped in circles from the pump discharge through the relief valve then back into the suction. imho there are very few engines that are going to flow what the pump does. i know Andy Finkbeiner did research on different pumps and he may have some accurate info as far as how much oil these engines are actually using. imho as mentioned using screens on the pump suction is a good.
