70 coronet Dash wiring help #543749
12/03/09 03:34 AM
12/03/09 03:34 AM
NE
moparpoolman Offline OP
NE
Need some help guys, When I turn on my lights the turn signal indicators light up along with the dash lights. The turn indicators still work when the flashers are on and when the turn signals are on. Thought it might be the dimmer but changed it and still having a problem. Anyone ever have this problem?? Suggestions???
Re: 70 coronet Dash wiring help [Re: moparpoolman] #543750
12/03/09 11:11 AM
12/03/09 11:11 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm toward to a loosen socket at front parking lights, making CIRCUIT being the ground is bad there
Re: 70 coronet Dash wiring help [Re: moparpoolman] #543751
12/03/09 11:22 AM
12/03/09 11:22 AM
NE
NE
I do have a ground from battery to the radiator support and the dimmer switch has a factory ground to it. It seems like the cluster is also grounded. Still have the problem....
Re: 70 coronet Dash wiring help [Re: moparpoolman] #543752
12/03/09 04:17 PM
12/03/09 04:17 PM
New York City
groundpoint6 Offline
New York City
Make sure you have the proper bulbs at all 4 park/signal sockets. They should be 1157 bulbs dual filamint. If you have 1156 lamps in these sockets they will cause this problem. Also make sure the sockets are clean and have a good ground.
Re: 70 coronet Dash wiring help [Re: groundpoint6] #543753
12/03/09 04:48 PM
12/03/09 04:48 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Sounds like a bad socket ground.
Re: 70 coronet Dash wiring help [Re: stumpy] #543754
12/04/09 02:21 AM
12/04/09 02:21 AM
NE
NE
Thanks for the suggestions, But I think I found the problem, The screws holding the circuit board to the instrument panel also ground the board. removed and cleaned the contact surfaces and the problem went away. NEVER thought that was going to be it.
Re: 70 coronet Dash wiring help [Re: moparpoolman] #543755
12/04/09 11:13 AM
12/04/09 11:13 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well, either way a ground problem ;D
