1970 6 pack charger four speed floor pan "bump" #543447
12/02/09 08:45 PM
12/02/09 08:45 PM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
Hey guys,
I'm just finishing up some metal work on my orange 70 six pack charger and noticed an area on the passenger side front floor pan at the inside corner right at the base of the tranny tunnel. The corner of the floor pan appears to have been hammered upwards with a ball peen hammer in a perfect circle about the size of a baseball...it's too clean to just be an accidental dent... I had first thought that a previous owner just needed clearance for something back in the cars racing days but decided to check my black 70 six pack four speed charger and found the exact same thing in the exact same spot... That car is all together and I can't see any reason underneath for needing additional clearance in that spot.
Was this done at the factory for some reason? or do both my four speed 1970 six pack cars just have a coincidental "alteration" to the floor pan... none of my automatic chargers have it.
Any help is appreciated as I don't want to fix something if it is supposed to be there....
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: 1970 6 pack charger four speed floor pan "bump" [Re: smac77] #543448
12/02/09 09:39 PM
12/02/09 09:39 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
Re: 1970 6 pack charger four speed floor pan "bump" [Re: smac77] #543449
12/05/09 03:45 AM
12/05/09 03:45 AM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
anyone???
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
Re: 1970 6 pack charger four speed floor pan "bump" [Re: smac77] #543450
12/05/09 05:29 AM
12/05/09 05:29 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
A picture may jog some memories.
I can't afford this. mark
Re: 1970 6 pack charger four speed floor pan "bump" [Re: smac77] #543451
12/05/09 01:14 PM
12/05/09 01:14 PM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
here's a pic...
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
Re: 1970 6 pack charger four speed floor pan "bump" [Re: smac77] #543452
12/05/09 01:27 PM
12/05/09 01:27 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I just looked at my buddies '70 RR 4-speed ragtop which was built at the G-plant (same as your cars), and it doesn't have any dent there... That looks pretty crude and I also see no reason why it would have been necessary to have done such a mod at the factory I owned a '70 V-code -spd Super Track Pak Charger RT a while back, I will see if I have some pics of that area.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 1970 6 pack charger four speed floor pan "bump" [Re: 70440+6bbl] #543453
12/05/09 01:55 PM
12/05/09 01:55 PM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
It definatley was beat "manually" and looks like crap but both my 70 4-speed six pack chargers have it in the same spot.(they came from different places) I checked both my 69 a-12 4-speed cars and neither of them have it... just the chargers... from the underside there appears to be no reason for it to be there....
It'll be easy to just beat it and shrink it back into shape but I didn't want to do it if it's supposed to be there...
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
Re: 1970 6 pack charger four speed floor pan "bump" [Re: smac77] #543454
12/05/09 04:01 PM
12/05/09 04:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
My buddies V code auto 70 Charger doesn't have it.. FWTW...
Re: 1970 6 pack charger four speed floor pan "bump" [Re: smac77] #543455
12/05/09 04:10 PM
12/05/09 04:10 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
I seem to recall seeing that feature on some cars that had headers installed, that a possibility?
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: 1970 6 pack charger four speed floor pan "bump" [Re: smac77] #543456
12/05/09 04:15 PM
12/05/09 04:15 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
check for gremlims in shop, or its now elf season, thats the first signs of there work.
MOPAR OR NO CAR
Re: 1970 6 pack charger four speed floor pan "bump" [Re: RTDaddy] #543457
12/08/09 07:35 PM
12/08/09 07:35 PM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
no headers on either one and I can't see them needing clearance in that location unless they were massive collectors?
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
Re: 1970 6 pack charger four speed floor pan "bump" [Re: smac77] #543458
12/08/09 07:42 PM
12/08/09 07:42 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
None of my '68-'70 B-bodies had that, including the one that had small dents and holes from a clutch explosion. That's what, 15 or so cars, Roadrunners & Chargers.
You have yourself a head-scratcher there.
Re: 1970 6 pack charger four speed floor pan "bump" [Re: topside] #543459
12/18/09 06:00 PM
12/18/09 06:00 PM
State of Flux
Dodge Don Offline
Dodge Don  Offline
State of Flux
Never seen a bump there on other 70 Chargers...V codes, R codes, U codes etc. No reason I can think of why one would even be needed. I'd lose the bump.
