Hi all
Ok now we got a motor and trans ready to go in BUT!!!
I need to understand something
We have a 11" housing and a 10 1/2 fly wheel and cluch setup ..
SO I need to know
1. Will i need this starter shim for sure ?
2. Can I use the 11" housing with the 10 1/2 set up ..
3. how is the 10 1/2 flywheel differ from a 11"
I know the ring gear 130 v 143.. is the OD the same ?
4. what is the tork on the flywheel bolts ?
you can see the car itself at the Mopar Alley's Mopar Ralley show this year on June 6th
David
