Re: Strongest paint remover is..... [Re: mikeysmopars] #542603
12/02/09 08:39 PM
12/02/09 08:39 PM
Kirkland, Washington
Pacnorthcuda Offline
This the real deal here, Aircraft Remover,
Will take everything but the Carburator. It expands with heat so be carefull when you open it.
Otherwise you'll be rolling around in the grass with a water hose.
Yea, you want the stongest concentration of Methylene chloride you can find. Its pretty nasty stuff. Our company (BIG manufacturing firm) won't allow a drop of it in the plants. Known carcinogen.
But it works
Re: Strongest paint remover is..... [Re: Pacnorthcuda] #542604
12/03/09 09:58 PM
12/03/09 09:58 PM
Jacksonville Florida
elitecustombody Offline
Aircraft stripper works great if you follow directions when applying it, covering it with plastic sheet helps to get faster and better results
Re: Strongest paint remover is..... [Re: Topcat] #542605
12/04/09 01:00 AM
12/04/09 01:00 AM
I used circa 1850 and had no problems.
Re: Strongest paint remover is..... [Re: Topcat] #542606
12/04/09 12:52 PM
12/04/09 12:52 PM
auburn,N.Y.
71RR ED Offline
71RR ED  Offline
auburn,N.Y.
used aircraft stripper and as was said factory primer was the only layer that did not lift.
Re: Strongest paint remover is..... [Re: 70Duster440] #542607
12/05/09 04:22 PM
12/05/09 04:22 PM
CHRGR69 Offline
CHRGR69  Offline
The Jasco stuff is practically worthless. Aircraft stripper will do it. If your local hardware store doesn't have it, an automotive paint supplier will.
Maybe for body paint, but the Jasco works great for underhood and interior stripping.
Grandma always said I had "hands of gold"!
Re: Strongest paint remover is..... [Re: Topcat] #542608
12/06/09 01:21 AM
12/06/09 01:21 AM
Texas
Texican Offline
Texican  Offline
Texas
Methylene Chloride works ok and so does MEK (methyl ethyl keytone) which can be bought at the local paint store (very dangerous stuff to breathe)... but all this stuff flashes off very quickly which is why aircraft stripper comes in a gel form.
Although aircraft stripper works better on most paints, I've had good luck with heavy duty easy off oven cleaner with some paints that were stubborn....and when all else fails, there's always brake fluid
