new 505 motor thoughts....
#542542
12/01/09 10:45 PM
12/01/09 10:45 PM
Posts: 642 South Dakota
dakotahotrodder
South Dakota
How does this 505 ci set up sound? This would be using what I have on hand with the exception of the stroker kit. I would like to know if anyone is running a similar combo and their performance, also what kind of hp do you think with this cam and these heads? I figure this should be right at 12.24:1 compression.
Block: -1969 440, (tall fill??) -Bored .030 -Decked and squared to 10.710 deck height (pistons are flush with deck) -Oil passage enlarged for ˝” pickup and main bearing “feeds” reamed to 9/32” -Line bored and fitted with BCR aluminum main caps -ARP main studs with 440 Source main girdle -Deburred, lifter valley smoothed and polished
Rotating Assembly: -4.25 stroke crankshaft (Muscle Motors Racing). -H-beam rods (muscle Motors Racing) -Forged flat top pistons with plasma moly ring pack (file fit) -Clevite race bearings -Balanced assembly from Muscle Motors Racing
Heads: -Edelbrock aluminum, 28 lbs each -Fully CNC ported by Straightline Performance (not max wedge opening) -Deck surface has been milled .030 for 78cc combustion chambers
Valvetrain: -Lunati solid roller cam & lifters -270/276 @50, .647/.647 lift, 108 lsa -Indy SR 1.5 roller rockers and shafts -Hughes Engines billet rocker shaft hold downs (set to .015 clearance per pair) -Manton 3 series, 3/8 x .083 wall custom pushrods -Rollmaster billet timing set w/ Torrington bearing -Lunati valve springs, 10° locks & retainers (??? Pressure) -Comp Cams lash caps
Miscellaneous: -Mopar M1 intake, milled .015 to fit -Holley 950 HP race carb -TCI “Rattler” balancer -440 Source 7 qt. Oil pan with ˝” pickup and windage tray -Melling HV oil pump -Hooker 2” Super Comp headers (ceramic coated) -Mopar aluminum water pump housing with Milodon hi flow water pump -Cometic head gaskets, .040 thick, 4.410 bore
Re: new 505 motor thoughts....
[Re: dakotahotrodder]
#542545
12/01/09 11:41 PM
12/01/09 11:41 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Be careful on how full you fill the block, I stopped at 3" below deck, if you go more you might get into heating problems. BCR aluminum caps are a good move, his whole kit is a work of art. I run a .650 lift cam with 1.5 roller rockers, could go more . Most of your build is close to mine except the pistons, mines a pump gas dog.
#542546
12/02/09 02:00 AM
12/02/09 02:00 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
I'd run victor heads. Also, if you're going to run BCR caps, get their whole cap and girdle system. We've built two similar engines to this, minus head porting. One was a 496 (383 with 4.250 stroke). cam was in the 250@.050 range and it made 570 hp. Victor intake. Built a 493 440 based motor with the same heads and a cross ram intake and it made 571 hp. You'd be looking at over 600 Fairly easily I think as you have more compression, more head and more cam.
#542547
12/02/09 02:36 AM
12/02/09 02:36 AM
Posts: 718 Vallejo California
T748
super street
super street
Vallejo California
I've got a motor thats kind of close to what your building. It's got a bit more compression (13.3:1) and a bit bigger cam and a few less CI's (496). Heres the details using your "form". Block: -1974 440 tall fill -Bored .040 -Decked -External oil dual line swinging pickup. main bearing “feeds” reamed to 9/32”. -Line bored and fitted with BCR aluminum main caps -ARP main studs
Rotating Assembly: -4.15 stroke Eagle crankshaft. -H-beam rods, Manley. -Forged JE Dome pistons with moly ring pack (file fit) -Clevite bearings -Balanced assembly
Heads: -Edelbrock aluminum RPM heads. -Fully CNC ported by MCH (not max wedge opening) -Deck surface has been milled
Valvetrain: -Schnider solid roller cam -282/286 @50, .693/.684 lift, 108 lsa -HS roller rockers and shafts -Pete Jackson gear drive
Miscellaneous: -Weiand TeamG intake -Holley 1050 3 circuitDominator -ATI balancer -Milodon 10qt “pre 65” pan, swinging pickup and windage tray -Melling HV oil pump -Proparts 2” headers (ceramic coated) -Meziere electric water pump -Cometic head gaskets
Dyno'd at 679.5 HP at 6500 and 621.6 TQ at 5000 rpm. -Tom.
#542549
12/02/09 09:52 AM
12/02/09 09:52 AM
Posts: 1,402 State of Corruption
camdog440
State of Corruption
"Heads: -Edelbrock aluminum, 28 lbs each -Fully CNC ported by Straightline Performance (not max wedge opening) -Deck surface has been milled .030 for 78cc combustion chambers" Straightline Performance does CNC work?
#542551
12/02/09 10:27 AM
12/02/09 10:27 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Looks good to me. The small intake runners will keep the power fairly low, and it should live well there. I am not comfortable with only a seven quart pan though. That is close to the edge. I would put a large line on the oil pressure gauge to make it very sensitive, and keep a very close eye on it.
#542553
12/02/09 02:04 PM
12/02/09 02:04 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
There are several things I don't like on your choices, first is this s arace only or dual purpose motor? If dual I think the cam is to big, probally to big for race only even I would try around(and have) 255 to 265@ .050 on both lobes at 108 installed at 104 second thing is the drilling the block for 1/2 pickup and enlarging the oil main feeds, not needed Are you using full groove main bearings? If no do so, use the Federal Mogul narrow groove truck bearings Last two things is the fill, not needed also if you have a good block I sell both Manton and Smith Bros pushrods, .083 on a roller cam is a disaster waiting to happen, use them on some other project and get a set of 3/8 x .120 wall or larger BTW my pump gas 512(400 block 4.250 x 4.375 bore, 9.25 to 1 compression) using a set of ported 906 heads with big valves made and a Comp Cams [Email]260@.050[/Email] with .420 lobe lift made 612 HP at 5600 RPM and 644 Ft. Lbs at 4500 RPM on CA pump gas using a stock type low deck six pak set up yours should make(with the higher compression) 640+ Hp As far as valve spring pressure try 250 lbs + closed and 600 + Lbs. open
