Page 1 of 3 1 2 3
Jesel or T&D Individual Shaft Rockers #541943
12/01/09 02:37 PM
12/01/09 02:37 PM
sg66mopar Offline OP
My new B1 heads should be ready for Koffel's to set up with rocker gear pretty soon and I need to decide between Jesel or T&D rockers. Has anybody here used or at least had some experience with both?
Re: Jesel or T&D Individual Shaft Rockers [Re: sg66mopar] #541944
12/01/09 02:38 PM
12/01/09 02:38 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I am in the market as well....maybe we can get a deal if we buy two sets
Re: Jesel or T&D Individual Shaft Rockers [Re: sg66mopar] #541945
12/01/09 02:45 PM
12/01/09 02:45 PM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
I have a set of each on 2 different cars and no complaints on either one....I do know that Jesel charges alot to rebuild there's.
Re: Jesel or T&D Individual Shaft Rockers [Re: joshking440] #541946
12/01/09 02:45 PM
12/01/09 02:45 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I use Jessel individual shaft and have single shaft T&D's on my other motor. The Jessel's are really nice, and so are the T&D's, but the individual system is by far the best. The Jessels require alot of machine work, and the T&D's don't. That would make my mind up.
Re: Jesel or T&D Individual Shaft Rockers [Re: camastomcat] #541947
12/01/09 03:05 PM
12/01/09 03:05 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Jesel is about as good as it gets. They also allow for large diameter springs which the T&D in some cases do not.
I would advise going with pushrod oiling also. I ran spray bar oiling on my engine, and had no trouble. I actually made my own spray bar/lines setup.
If starting from scratch I would have had the Indy Maxx block drilled to allow pushrod oiling. But my machine shop couldnt do it.
The spray bar covers and setup isnt real cheap $400+ so the costs of having the lifter bores drilled should actually save some money. The push rods are Not any more money with the oil holes.
If you are interested in making your own spray bar lines..I wouldnt care to share how I did them
Re: Jesel or T&D Individual Shaft Rockers [Re: joshking440] #541948
12/01/09 10:32 PM
12/01/09 10:32 PM
I think it might take more than two sets. Anybody else interested? Maybe an early
Re: Jesel or T&D Individual Shaft Rockers [Re: Bob_Coomer] #541949
12/01/09 10:37 PM
12/01/09 10:37 PM
Hey Bob, would or wouldn't? Sure would like to see.
Re: Jesel or T&D Individual Shaft Rockers [Re: sg66mopar] #541950
12/02/09 01:03 AM
12/02/09 01:03 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
T&D individual shaft is the best option IMO. Been working for me with zero issues. BTW fwiw my springs are 1.677 diameter and the rockers clear with NO issues or clearancing and i pushrod oil as well.
Re: Jesel or T&D Individual Shaft Rockers [Re: Al_Alguire] #541951
12/02/09 01:17 AM
12/02/09 01:17 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
As told by a guy who used to work at T&D, the Jesels use a "spray and pray" oiling setup while the T&D's have pressurized oiling from the adjuster to the trunion bearings.
I don't think you could go wrong with either set.
Re: Jesel or T&D Individual Shaft Rockers [Re: sg66mopar] #541952
12/02/09 08:10 AM
12/02/09 08:10 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
You have a good product. And I think your willing to do what it takes ($) to build a smart powerful package. My concern is your last post. Most here lead you down the path of better rockers ($). But contradictory to us 'experts' B1Headman posts this in the Greg'sDart valvetrain post.
"Two set ups 1st is our std. N/A set up 250-260 seat load 760-800 open load 1.7 std. B1 rockers .780-.800 lift comp 829-16 lifters. 3/8 int pushrods & 7/16 ex pushrods. 2nd set up is for blown applications.
>>>(350-370 seat load and 1050-1100 open load. 1.7 std. B1 rockers)<<<!!! .850 lift. 1/2 int and ex pushrods. Crane pro series lifters.We run this combo 8800-9000 rpm."
This would lead me to believe the 'kit' rockers you already purchased where more than adequate. Why are you changing rockers? Just didn't want you to spend $ unnecessarily, also would like to better understand your decision snce you've already involved us. And better educate us 'experts'.
Re: Jesel or T&D Individual Shaft Rockers [Re: camastomcat] #541953
12/02/09 08:22 AM
12/02/09 08:22 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
The way I understand this is that you can purchase either the individual 'paired' shaft rockers which require machining or buy a bolt-on kit. I believe T&D make individual 'paired' rockers which also require machining.
Re: Jesel or T&D Individual Shaft Rockers [Re: HardcoreB] #541954
12/02/09 08:51 AM
12/02/09 08:51 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
What I meant to say is, I run the Jessels and they are pushrod fed oiling individual shaft rockers. They work great, but required alot of machine work to fit. I also run the single shaft T&D's and they worked fine, once the pushrod length was perfect, and I mean it needs to be perfect. But when I build my next rocker system, it will be with T&D individual shaft system, because they don't require the extra machine work that the Jessel's do. I have also used the Koffel black rockers, and they worked fine for me. I did order the torington bearing kit from Tom Hemphil for the rocker shafts. He is in PA and can help with that. But if you are set on individual shaft system, pushrod oiling is the only way to go IMO.
Re: Jesel or T&D Individual Shaft Rockers [Re: HardcoreB] #541955
12/02/09 08:51 AM
12/02/09 08:51 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Do the T&D rockers that require no machining need to oil through the push rod?
Re: Jesel or T&D Individual Shaft Rockers [Re: joshking440] #541956
12/02/09 08:53 AM
12/02/09 08:53 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
The individual shaft Jessel or T&D require either spray bar, or pushrod oiling.
Re: Jesel or T&D Individual Shaft Rockers [Re: camastomcat] #541957
12/02/09 10:21 AM
12/02/09 10:21 AM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
My vote is the T&D individual shaft rockers. My Engine guy Tom HEMPHILL ordered the Jesel & got to looking what it would take to make them work & decided to fall back on the tried & true T&D that he has used for years on B1 stuff.
One thing to watch for is when you install the rockers make a few pulls & check to be sure the rollers aren't locked up. Mine were soaked in oil for a day or two like the instructions say & 3 were stiff & it scored the roller. One had to be replaced the others were removed, polished & reinstalled.
GOOD LUCK
Re: Jesel or T&D Individual Shaft Rockers [Re: V10nacuda] #541958
12/02/09 10:39 AM
12/02/09 10:39 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
We've had great luck with Jesel's.
Re: Jesel or T&D Individual Shaft Rockers [Re: HardcoreB] #541959
12/02/09 12:05 PM
12/02/09 12:05 PM
Sean, Koffel's still has the heads so I was hoping I could just have them do an "upgrade" to the Jesel or TD setup and get them to adjust the pricing. I mentioned to Scott when I ordered that I might want to go this route, don't know if he'll remember.
We broke a rocker on the Indy set-up we ran last year and now we're paranoid. That's the biggest reason we're switching heads. Figured if we had to spend money on better rockers it might as well be on better heads also.
I know Koffel, along with a lot of other people use the standard B1 rockers without problems. That's OK for people who have the resources to fix broken parts and go racing again the next weekend but that's not me. At my stage in life and with the money involved, if I grenade this motor I'm probably all done racing.
Re: Jesel or T&D Individual Shaft Rockers [Re: sg66mopar] #541960
12/02/09 06:06 PM
12/02/09 06:06 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Seriously, you could flip a coin on the rockers. Since you're in Oregon I'd consider T&D's just because if you do need parts, they're only a state and a half away from you.
Re: Jesel or T&D Individual Shaft Rockers [Re: sg66mopar] #541961
12/02/09 06:24 PM
12/02/09 06:24 PM
Pay now and get the good stuff, have Koffels do it for you now so you don't have to pay more later when it breaks, if if(the black rockers) ever does
Re: Jesel or T&D Individual Shaft Rockers [Re: Cab_Burge] #541962
08/19/14 02:30 AM
08/19/14 02:30 AM
long island NY
Ari440 Online content
Ari440  Online Content
long island NY
HOW MUCH MONEY ARE THE T/D AND JESSEL SETUP
1.39 9.85 - 137 mph
Page 1 of 3 1 2 3
